Home > Wheels & Tyres > Offroad tyres for standard steels; D rings new Defenders
Page 2 of 2 <12
RRUK
Could be a great opportunity to give the Defender a gift and put a whole new set of alloys and tyres on? Gives you MUCH more scope....
Some black sawtooths with BFG AT KO2 would look nice on your green machine...
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #499961 3rd Feb 2016 4:47pm
^^ Looking at the photo above, I am not even sure that the modified elongated-baseplate D rings would fit with that grille.
Post #499962 3rd Feb 2016 4:49pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I had them on my 300Tdi and had room to spare, but you're right they look a tight fit with an aircon grill.
Re: the Jate rings. While being less exposed, they are under the vehicle and when you're stuck in the mud it's often hard to reach them without doing some digging...😀
Simon
Post #499985 3rd Feb 2016 5:53pm
jk84
It's never simple with our beloved Defenders Very Happy
Thanks blackwolf for pointing that out. I guess I'll get a pair and try it out, it's not too expensive, and as Simon noted, looks to be a tad neater than digging into mud to fish the jait rings out Wink
The space does look tight though, will see.
Will post a picture here if they fit fine, so others who might be interested to fit them to latest Defenders can reference the thread.
RRUK, those look tasty, but would be too worried scratching them off-road Very Happy Would be nice to have them as a 'shiny' set for special occasions! Maybe one day... MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
MY16 Santorini 90 HT - sold
Post #500169 4th Feb 2016 12:17am
couplands
Another option that fits on the existing number bolts but doesn't look like it will foul the aircon grill.
Not tried them, so can't be sure...
http://www.frogsisland4x4.com/towing_equip/towing_equipTFBRP
Simon
Post #500178 4th Feb 2016 12:42am
jk84, I have a pair of the elongated type knocking about somewhere (I think I even know where they are!). I will see if I can dig them out and take a photo this evening to show the proportions of them, then you might be able to determine if that type would do what you want.
Unfortunately I don't have access to an a/c fitted vehicle to offer them up to.
Post #500230 4th Feb 2016 10:35am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
I'd go for a set of these: http://www.mudstuff.co.uk/recovery-eyes.html
Look subtle, works with air con grille, and easy access. Done.
Post #500302 4th Feb 2016 12:12pm
^^ They're nice, in many ways they're the 21st Century version of the original D ring.
The only disadvantage I can see is that you have to use a shackle and can't really just tie a rope to them.
Post #500367 4th Feb 2016 1:25pm
couplands
FYI: here is a photo of my old TDi with the D rings fitted. Certainly wont fit with an aircon grill...Wink
cheers
simon
Post #500437 4th Feb 2016 3:31pm
They're the standard ones, aren't they, not the elongated ones.
Post #500441 4th Feb 2016 3:42pm
couplands
Yes, they're the originals. I didn't mean to suggest they were the elongated ones, it was just for reference.
I recall that I always used shackles when attaching the rope, so I don't think that would be an issue with those MUDstuff ones above.
cheers
simon
Post #500450 4th Feb 2016 3:58pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I can also vouch for XZLs being quite noisy, my BFG mud KM2s that replaced them are quieter.
they are however surprisingly good in mud, very good in the snow but I have to say I disagree with those who have said they are good in the wet- they could actually be a bit 'exciting' in the wet- particularly under braking.
The XZLs also seem to have a very stiff sidewall which, (even when I tried various tyre pressures) make for quite a fidgety, lumpy ride!
Chris
Post #500453 4th Feb 2016 4:13pm
jk84
Thanks blackwolf, kind of you. Looks like L90Andy have spared you of that one though.
Well spotted, problem solved indeed...just the price is a bit zee german premium Mr. Green But looks a solid product!
cheers
simon
That's in a nice shade, that 90 is, Simon Wink
Interesting observations, thanks Chris.Sounds like the XZLs are probably best candidate for an extra set of wheels to put on when off-roading. Or perhaps for skiing trips. Otherwise a set of some shiny alloys with road friendly tyres for normal use - logical excuse to wifey for 'having' to spend more money on the Defender Very Happy MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
Post #500684 5th Feb 2016 12:31am
miker
http://www.4x4overlander.com/product/recovery-eyes-defender/
These are basically a cheaper version of the GMB eyes!
Post #500691 5th Feb 2016 1:27am
If you can't reach them without digging then that suggests you should get the shovel out irrespective of whether you have D rings on the bumper or not.
Be aware the older D rings had a chassis designed to take the loads. I'm not aware anyone has really designed these Puma versions - the bumper bolts are not actually fastened with a real nut and the final version detailed above makes me cringe - those front two fasteners have no load spreading plate and are attached to a particularly fragile area of the bumper with skimpy set screws.
JATE rings - designed for the purpose when form over function is not the primary purchasing criteria.
Food for thought:
http://www.defender2.net/forum/topic43870.html
Post #500879 5th Feb 2016 3:52pm
Page 2 of 2 <12
