![]() | Home > Technical > a bad connection maybe ? |
pulled off the drive last night and the interior light came on then off followed by a bang which I'm sure was the back door slamming shut.
I wasn't aware of the back door having an electro/hydraulic ram which in my case has a bad electrical connection linked to the interior lights so could it be a bad connection in my head causing me to over look shutting the back door before I pulled off ? |
I was expecting a lot of office - wouldn't have posted it otherwise
![]() and going by how many times I've done it - very much deserved. ![]() |
You know what I think you have Wayne?
E.S.P: Extra Sensory Perception. I bet if you tried hard you could levitate and move large objects just by the power of thought alone. That, combined with an over active imagination, is truly an amazing gift. Do you see dead people too? ![]() ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
with comments like that Steve I'm thinking the back is on the road to recovery?
- I hope so anyway ![]() |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5132 ![]() ![]() ![]() |
Having explored all avenues with you in the past regarding your many Defenders abnormalities, I now suggest you contact a priest in order for him to perform and exorcism on your Defender, if that fails then I suggest you contact NASA or the NSA, as the only other explanation to explain these phenomenon’s you are experiencing with your Land Rover would be aliens from another world messing about with it.
![]() http://www.youtube.com/user/conwy1 |
as you may have guessed....this post being one example but I kid you not gilarion I've actually wondered on several occasions if some joker of a mechanic has had this great idea of sliding under my truck in the middle of the night to fix or break stuff depending on what mood he's in.......
hadn't thought about aliens but clearly that another avenue I could explore assuming the CCTV would pick them up and the infra red light doesn't frighten them off. |
Still hurting Wayne, but not to worry, I can still use a keyboard
![]() ![]() Click image to enlarge Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
good you can still use the keyboard
