![]() | Home > In Car Electronics > Security Upgrades |
PM sent
Striker Member Since: 04 May 2013 Location: Yorkshire Posts: 127 ![]() |
Could you also pm the details please.
![]() Also whilst I have the rear tub off my Defender can I modify the fuel system. Re, a fuel cut off valve or electrical cut off switch or both without causing airlock problems. Cheers Andy Never Knowingly Understood |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7926 ![]() ![]() ![]() |
I too am very unsure on what and how much security to get. I know you need layers but its a fine balance between lots of security and everyday usability. I don't' want to spend 10 minutes just to unlock/disable/remove to run 10 minutes down the road. Also the more you add the more to go wrong/cause conflict?!?!
If only people would stop stealing them!! It's mine and I want to keep it thank you!! ![]() |
claydiggermud Member Since: 11 Jul 2015 Location: west country Posts: 86 ![]() ![]() ![]() |
Can you also pm me please.
![]() Thanks claydiggermud |
Check out our thread started today
PM to me also, please... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
The easy st way i can think off is to put a relay between the 2 signal resistors of the E-throttle.
http://www.velleman.eu/products/view/?coun...;id=375928 or use it to interupt the main relay , or a few injectors. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 603 ![]() ![]() ![]() |
I would appreciate a PM on simple TD5 electrical security options.
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
can you pm me also! ![]() |
andre.prum Member Since: 24 Feb 2014 Location: Bridel Posts: 8 ![]() ![]() ![]() |
Tanks for sending PM also for a Defendr 2.4 Puma year 2011 and a Defender Puma 2015
Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 23 ![]() ![]() ![]() |
Thanks to sent me a PM also for the PUMA 2.4
Regards |
richardg Member Since: 17 Dec 2012 Location: Cumbria Posts: 30 ![]() ![]() |
Could you send me a PM also ? Many thanks
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
And me please
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Could you send pm about 2.4 to me as well
