Home > In Car Electronics > Security Upgrades
Page 1 of 8 12345678>
Morepower
New Zealand
Security Upgrades
Hi Guy's... Can you please pm me with easy/sensible or interesting electrical security upgrades for late model 2.2 pumas...
I've read somewhere that the std alarm can be upgraded / modified to make a lot more protective... But I can't find any info with the search (could just be me being thick here)...
Just with all the reports of stolen defenders I'd like to keep these two
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #488717 5th Jan 2016 2:25am
PM sent Thumbs Up
Post #488726 5th Jan 2016 7:59am
Striker
Could you also pm the details please. Thumbs Up
Also whilst I have the rear tub off my Defender can I modify the fuel system. Re, a fuel cut off valve or electrical cut off switch or both without causing airlock problems. Cheers Andy
Never Knowingly Understood
Post #488728 5th Jan 2016 8:31am
JOW240725
I too am very unsure on what and how much security to get. I know you need layers but its a fine balance between lots of security and everyday usability. I don't' want to spend 10 minutes just to unlock/disable/remove to run 10 minutes down the road. Also the more you add the more to go wrong/cause conflict?!?!
If only people would stop stealing them!! It's mine and I want to keep it thank you!! Big Cry
Post #488823 5th Jan 2016 2:30pm
claydiggermud
United Kingdom 2014 Defender 90 Puma 2.2 HT Tamar Blue
Can you also pm me please. Very Happy
Thanks claydiggermud
Post #496792 26th Jan 2016 9:11pm
Check out our thread started today Thumbs Up
Post #496793 26th Jan 2016 9:13pm
dgardel
Italy
PM to me also, please... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #496888 27th Jan 2016 12:11am
Alexke
Belgium
The easy st way i can think off is to put a relay between the 2 signal resistors of the E-throttle.
http://www.velleman.eu/products/view/?coun...;id=375928
or use it to interupt the main relay , or a few injectors. Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #496899 27th Jan 2016 1:01am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I would appreciate a PM on simple TD5 electrical security options. Bow down
Post #498227 30th Jan 2016 12:23pm
nitram17
Go Beyond wrote:
PM sent Thumbs Up
can you pm me also! Thumbs Up
Post #498246 30th Jan 2016 2:21pm
andre.prum
Luxembourg 2011 Defender 110 Puma 2.4 SW Fuji White
Tanks for sending PM also for a Defendr 2.4 Puma year 2011 and a Defender Puma 2015
Post #498574 31st Jan 2016 12:38pm
Fiebre
Spain 2008 Defender 90 Puma 2.4 SW Java Black
Thanks to sent me a PM also for the PUMA 2.4
Regards
Post #498590 31st Jan 2016 1:38pm
richardg
2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Could you send me a PM also ? Many thanks
Post #500076 3rd Feb 2016 9:33pm
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
And me please
Post #500141 3rd Feb 2016 11:18pm
williamthedog
Could you send pm about 2.4 to me as well Thumbs Up
Post #500206 4th Feb 2016 9:18am
