Home > My Defender > 2004 110 TD5 CSW |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
excellent look forward to seeing what you do with it! nice to see it being used properly too. My 109 thread
my youtube channel |
26th Jan 2016 9:12am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Nice Looking truck
I look froward to your updates, she seems busy! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
26th Jan 2016 1:51pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10491 |
as above Clayton. |
26th Jan 2016 11:38pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1332 |
Yep, nearly 750 miles in 16 days. It will calm down a little, i have new car syndrome which means i want to use it for evry journey Working again last night, people keep asking me if i've sold the D4 Click image to enlarge |
27th Jan 2016 8:53am |
jb71 Member Since: 11 Jul 2015 Location: East Sussex Posts: 103 |
Very nice!..... And then there's the RS Turbo
27th Jan 2016 9:58am |
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 48 |
Does the spary foam actual get the vehicle clean, or do you still need to agitate said foam to remove all the crud? Thinking of buying an attachment for my Karcher.
27th Jan 2016 3:09pm |
It does if used correctly, firstly the car needs to be polished, waxed and sealed using decent products.
The snow foam needs to be filled with warm water to activate ir properly and then leave it to dwell for approx 15 minutes, i usually re coat it after 10 mins. then blast off. I haven't washed my RS Turbo by hand for probably 3 years, the snow foam removes flys, brake dust and other crap well, but all areas MUST be sealed, it's a tedious job to get the car right in first plsce, but worth it when it comes to cleaning. Also, my RS probably never does more than 100 mile between washes. |
27th Jan 2016 3:42pm |
Well i've successfully bent my steering guard and i've no idea how, it's an ally one so i might of done it in the snow, these pictures are post straightening as it was a lot worse
Click image to enlarge Click image to enlarge Last day on the shoot 2016, dirty girl can now have a proper wash again and carpets wet vacced. Click image to enlarge |
1st Feb 2016 9:16am |
It must have been a decent bump to bend that Ray
1st Feb 2016 11:32am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Nice.
As we all know like a fine wines a Defenders quality is very dependent on the year. 2004 I believe was the very best year. |
1st Feb 2016 12:08pm |
I'll see if i can get a replacement at the donnington show next weekend, as much as it still works and is purposeful, i don't like the fact it's bent.
1st Feb 2016 1:30pm |
Today I set about whipping door card off as CL not working. Found problem and part ordered.
Glad I had my pick set as removing the horse shoe clip on window winder was tricky. Also found my door seals were cause of the wet foot wells so going to treat it to a full new set including bottom seals and weather strips Click image to enlarge |
14th Feb 2016 7:07pm |
Also I went to donnington 4x4 show. Bought new steering guard and some wind deflectors. As well as extended front seat rails from 4x4 over lander.
Will get them fitted next weekend or one night this week but got the wind deflectors fitted when I got home Click image to enlarge |
14th Feb 2016 7:09pm |
Click image to enlarge Went to Wales and picked up a D1 |
14th Feb 2016 7:12pm |
