![]() | Home > My Defender > New to me Keswick 90 |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
New to me, going to convert to a soft top.
Going to try & keep classic look ![]() Picture as it came to me ![]() Currently has lost the IW top & will soon be losing the truck cab Will post pictures as it changes 2020 P300 HSE |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Love them both !!!
looking forward to the transformation ![]() |
CY88 Member Since: 05 Jan 2016 Location: Offshore Posts: 255 ![]() ![]() |
Looking good!
![]() What does the signwriting say? |
It's from Matt at FCX, so it would have been his Outfitters logo
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Looking forward to reading the updates on this, be sure to put lots of photos up as think it will have great results.
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049 ![]() ![]() |
As above ![]() Clayton. |
Started the conversion into a soft top today
Removed the truck cab, trial fitted the hood frame & started the bulkhead removal Pleased with the progress so far😄 2020 P300 HSE |
Attached pictures
Struggling to do on my phone Before - Thanks FCX ![]() ![]() Click image to enlarge Removing the truck cab ![]() Click image to enlarge ![]() Click image to enlarge Trial fit Hoops - Went galvanised as wanted a "classic" look - Thanks Purely Metal Ltd ![]() ![]() Click image to enlarge ![]() Click image to enlarge Bulkhead removal - Hoops help keep it nice & square - need a gulp emotican ![]() Click image to enlarge Bulkhead - most removed - Just need to tidy up the edges & remove the bit closet to the wings ![]() Click image to enlarge ![]() Click image to enlarge Will post as it moves on ![]() |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
Really enjoying this
![]() I look forward to the next installment ![]() |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Amazing work in no time flat!
![]() This will look brill! ![]() |
Tidied up the removal of the rest of the bulkhead & fitted one of the new bulkhead support bars
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Once I have drilled all the holes, I will then tidy up the cut edges & paint any bare metal. Bit of advice should I put a gasket between the metal of the bulkhead removal bar where it bolts to the wheel arches etc ![]() Conscious that it is steel mated to aluminium ![]() Ps the wavy edge is just the panel bonding material I've not cleaned off not a dodgey cut 2020 P300 HSE |
Top job. I would be fitting a gasket. For the size you have, go see your local tyre shop and ask for an old car or motorbike inner tube, then cut to size.
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
![]() Stephen |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Fantastic job. I would fit a gasket. 1mm rubber sheet. Will take up any tolerance and avoid any water escaping
![]() But you know what your doing anyway ![]() ![]() ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
