Home > My Defender > New to me Keswick 90
Page 1 of 3 123>
pjb
New to me, going to convert to a soft top.
Going to try & keep classic look Thumbs Up
Picture as it came to me
Currently has lost the IW top & will soon be losing the truck cab
Will post pictures as it changes 2020 P300 HSE
Post #496468 26th Jan 2016 8:43am
sib
I don't blame you.
 Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #496476 26th Jan 2016 9:02am
Love them both !!!
looking forward to the transformation Cool
Post #496481 26th Jan 2016 9:07am
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
Looking good! Thumbs Up
What does the signwriting say?
Post #496502 26th Jan 2016 9:32am
It's from Matt at FCX, so it would have been his Outfitters logo Thumbs Up
Post #496503 26th Jan 2016 9:33am
SailingTom
Looking forward to reading the updates on this, be sure to put lots of photos up as think it will have great results. Thumbs Up
Post #496516 26th Jan 2016 10:09am
L110CDL
As above Thumbs Up
Clayton.
Post #496877 26th Jan 2016 11:41pm
pjb
Started the conversion into a soft top today
Removed the truck cab, trial fitted the hood frame & started the bulkhead removal
Pleased with the progress so far😄 2020 P300 HSE
Post #498729 31st Jan 2016 6:32pm
pjb
Attached pictures
Struggling to do on my phone
Before - Thanks FCX Smile
Removing the truck cab
Trial fit Hoops - Went galvanised as wanted a "classic" look - Thanks Purely Metal Ltd Thumbs Up
Bulkhead removal - Hoops help keep it nice & square - need a gulp emotican
Bulkhead - most removed - Just need to tidy up the edges & remove the bit closet to the wings
Will post as it moves on Thumbs Up 2020 P300 HSE
Post #498965 1st Feb 2016 9:47am
steve E
Wales
Really enjoying this Very Happy
I look forward to the next installment Thumbs Up
Post #498976 1st Feb 2016 10:08am
YOLO110
Australia
Amazing work in no time flat! Cool
This will look brill! Thumbs Up YOLO... You Only Live Once...
Post #498982 1st Feb 2016 10:18am
pjb
Tidied up the removal of the rest of the bulkhead & fitted one of the new bulkhead support bars
Once I have drilled all the holes, I will then tidy up the cut edges & paint any bare metal.
Bit of advice should I put a gasket between the metal of the bulkhead removal bar where it bolts to the wheel arches etc Question
Conscious that it is steel mated to aluminium Exclamation
Ps the wavy edge is just the panel bonding material I've not cleaned off not a dodgey cut 2020 P300 HSE
Post #499426 2nd Feb 2016 8:31am
Top job. I would be fitting a gasket. For the size you have, go see your local tyre shop and ask for an old car or motorbike inner tube, then cut to size.
Post #499428 2nd Feb 2016 8:47am
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Thumbs Up looks great!
Stephen
Post #499433 2nd Feb 2016 9:07am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Fantastic job. I would fit a gasket. 1mm rubber sheet. Will take up any tolerance and avoid any water escaping Laughing
But you know what your doing anyway Thumbs Up Thumbs Up Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT�s,
Recaro CS�s, anorak, wellingtons
Post #499439 2nd Feb 2016 9:34am
Page 1 of 3 123>
