Home > In Car Electronics > Hi Beam lever/ switch - 1997 Defender
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
this is killing me (furstration)
I recently replaced the indicator/hi-lo and horn assembly due to the hi beam not working and the turns not cancelling.
every thing works fine but the hi beam. when its pushed forward (light on) it should set to hi beam and pulled back - hi-beam flash.
lo- beam is working fine, however hi-beam is the issue/symptoms.
I can get hi beam (dash warning light and hi-beam) if I push the lever forward 'just' in the right position. neither on or off on the lever (seems like contacts not making contact...?, not loose BTW
pulling the lever back for hi-beam flash - nadda, nothing at all
WTF
Post #492909 16th Jan 2016 12:48pm
miker
Sounds like a dodgy switch. Was it new or second hand?
I think you can get a look inside them and see what the contacts are doing if it's anything like the headlight switch.
Post #496290 25th Jan 2016 7:37pm
mk1collector
Did you buy britpart? Ray
My build thread
Post #496313 25th Jan 2016 8:25pm
