Home > Td5 > TD5 Fan control install?
Page 3 of 3 <123
Castillo
Finland
I did this mod one month ago. Here in finland has been -30 degrees cold now and this mod stopped work yesterday. Why? I have checked fan motor and electric and all is ok. If I drive for examble five minutes so fan can start blow some minutes and stop again. What is problem.
And I am sorry my poor english Confused defender 110 td5 2006
Post #495727 24th Jan 2016 9:38am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Castillo, your English is just fine, don't worry about that. If you are certain the wiring is correct and it WAS working well, I would contact Martin at Landrieziger and see about getting another module. Mine has been working great at that temperature here in Canada 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #495779 24th Jan 2016 12:32pm
g-mack
interesting mod, no reason this won't fit a tdi is there? My 109 thread
my youtube channel
Post #495799 24th Jan 2016 2:04pm
4RF RDS
Would work just fine. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #495817 24th Jan 2016 3:31pm
LandieG
i assume the only disadvantage is not being able to block the airflow completely, and given that is not like switching to recirculate, just blocking, can anyone see a reason (other than maybe cost) not to go ahead with this? or any down-side? what about for wading? would this blocking protect the heater against water coming in???
thanks for the thoughts...
G
Post #507506 24th Feb 2016 12:50am
4RF RDS
I haven't experienced any downside yet the convenience and simplicity of using it outweighs the cost. I also installed a snow cowl which would, in theory, help when deep wading. The blocking of the heater box is useful in extended deep wading but again for the amount of time I do that the convenience outweighs the cost.
Hope this helps. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #507542 24th Feb 2016 9:56am
Motoberg
From the wiring diagram I'm assuming that the resistor that changes the speed from slow to feeble in the circuit is physically located in the fan and not in the switch ?
Post #507661 24th Feb 2016 4:23pm
4RF RDS
The stock LR is in the heater box, separate from the fan. The kit has the solid state controller, separate on the outside of the heater box. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #507669 24th Feb 2016 4:38pm
Motoberg
Cheers, as long as its not in the stock slider switch I can change it out ...... one day Laughing
Post #507674 24th Feb 2016 4:47pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
4RF RDS wrote:
Also important to note that my Webasto pre-heater was unaffacted by this mod. All works as it should.
I recently installed this kit also - works really well
But it has affected my Webasto
The Webasto works fine as normal but unless the fan in on Full - the radio and all other electrics that normally only come on with the ignition all come on - this also includes the DRLs
So to work the Webasto I need to leave the fan on Full - this is not a problem as if the Webasto is needed then Full heat is also needed
Just curious as to why and how this is happening
The Webasto controls are independent of the ignition was it works when the vehicle is parked
Any ideas ?
Post #510188 3rd Mar 2016 1:23am
4RF RDS
I would trace the wiring and primary power to ensure that it was installed correctly. They should be two separate systems only linked via the main power of the wabasto when the timer triggers the ignition.
1967 MGB GT
Post #510633 4th Mar 2016 11:46am
Page 3 of 3 <123
