![]() | Home > Technical > Converting 7pin to 13pin towing electrics |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
Not specifically Puma but covered a bit here:
http://www.defender2.net/forum/topic39094.html?highlight=ignition 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| NJS22 Member Since: 26 Oct 2012 Location: Cornwall Posts: 169
I just use an adaptor plug, you can get both 7 to 13 or 13 to 7, I think I got mine from a trailer or caravan accessory shop about £5. 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure 2015 Range Rover Sport 1971 Range Rover 2 Door Wife won't let me have any more...!!! |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
The puma is a plug and play socket I believe so you simply need to purchase the 13 pin loom ??? Plugs in behind the offside rear arch
Plug and play except for the branch forwards for the ignition, as per my link above
2015 D90 XS SW |
| shipbadger Member Since: 10 Jan 2016 Location: Royal Forest of Dean Posts: 19
I recently had a trailer custom built and to pass the type approval at the testing station it had to be fitted with a 13 pin plug. When I collected it I realised I have only 7 pin sockets on my vehicles. The guys who built it dived into the workshop and plugged an adapter into the plug, job done.
Tony Comber |
