![]() | Home > Td5 > Daft Light Question |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I've fitted a similar loom, the lights change configuration after fitting, the headlights will be on at the first position, so there won't be a sidelight option.
I think it might be your dim-dip relay that could be suspect, an easy way to find out is unplug it. It's behind the clocks, easy to do. There's a few threads on here about it. If you want to get the sidelight option back that's easy too..... |
mrdelmonti Member Since: 08 Sep 2015 Location: South Northants Posts: 35 ![]() ![]() ![]() |
Yep sounds like the dim-dip relay to me. Get rid of it and bypass is the proper solution, there was never any need for it to be fitted in the first place.
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Thanks for tips. Will have a go over the weekend.
Final question, should the dip beam come on if engine not on it lights wired to alternator ???? Tank |
Not unless the ignition is on, if not on then it should just be sidelights.
That's what I thought , will check again !
Thanks |
Rather than spending £25 on a by-pass relay for the dim dip
http://www.brit-car.co.uk/product.php?xProd=138745 Can someone tell me which pins I should put the wire on to by-pass and I can make up a wire and spade terminals much cheaper ! Thanks Tank |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6688 ![]() ![]() ![]() |
http://www.defender2.net/forum/post198252.html#198252
The bridge is shown here but I highly recommend putting spades on the ends of the wires ![]() ![]() ![]() |
Thanks Martin.
Coming from the boss of the forum I feel honored ![]() ![]() ![]() ![]() ![]() Thank |
![]() The two outside middle ones Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Totally confused !
Took the tow bar electric plug apart and it was fine. No rust contacts all good. Still have the green light on the dash ! Rear lights work ok. Brake lights are really dim ?? The dim dip is knackered however when I do the wire bypass I have no lights, and I did the right bypass by the way. Can the brake light switch at the pendal not be working right and therefore not getting the voltage to the rear brake lights ? Aaaaaaaahhhhhh help Anyone know a good autoeletricain in Dunfermline ? Everything was working fine until my dim dip relay went ! Will guy another one in the mean time ! |
