Home > Maintenance & Modifications > school boy error....
Page 2 of 2 <12
dgardel
Italy
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #283178 18th Nov 2013 1:41pm
roel
With the rover V8's you had to fill the oil filter otherwise you would have problems getting oil-pressure. A short blast off air in the dipstick tube would help too. That's quicker then filling the oilpump with vaseline. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #283212 18th Nov 2013 5:01pm
Caterham
done a few miles today in the car and I had to do a sanity check........
I was careful how I worded this.....I asked my 10 year old daughter if she thought the car was any different after doing the 'service'.....her response - 'its louder'
I can't get my head round the car, having done a 'service' its now louder.....nothing that sounds wrong - it just sounds like someone has fitted a big bore exhaust to it Confused
its running really well but its just bl**dy strange?
Post #283311 18th Nov 2013 9:28pm
Caterham
Embarassed
found what was making the extra noise......contrary to me thinking someone had fitted a through pipe while I was asleep turns out some muppet didn't refit the airfilter box lid properly..... Whistle
Post #283593 19th Nov 2013 10:43pm
Glynparry25
Just a note for the guys filling the fuel filter up before fitting- if you get grit into it whether from the fuel/container or whilst re fitting throw it away- it will go straight down the line to the pump. I have changed my filter 3 times now and never filled it (touch wood I haven't ever had a air pocket in it) just start up and leave to idle for a minute.
x-isle wrote:
Don't forget to fill the air filter with air when you fit it too!.
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Yeah........ I got that right on the 3rd attempt and 4 tubs of Vaseline over 2 days- I got a funny look in the small shop the 3rd time I returned in 2 days Embarassed
Glyn Dog Sheep
Post #283605 19th Nov 2013 11:32pm
Caterham
just a thought Glyn,
where you fill the filter I think that might be on the 'entry' side ie prier to filtering?
the other thing is on the replacement filter heads there appears to be two little symbols - open and closed padlock. are these by any at the back where you can't see them...if so who decided to fit the filter housing the wrong way round Mr. Green
Post #489228 6th Jan 2016 4:18pm
spudfan
Ireland
If it sounds louder check your airfilter. If you have not fitted this correctly the airfilter lid will not be 100% closed. You will see some of the filter. It can be a bit awkward to get it (the top of the airfilter box) fitted correctly. It will sound very loud. Also a danger of water getting sucked in. Run your fingers around the join where the top meets the bottom of the filter box. If it is not closed correctly you get a very loud sound as you have described. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #489269 6th Jan 2016 6:14pm
Caterham
Thank you spud. You're right and all sorted now.
Thank you.
Post #489285 6th Jan 2016 6:43pm
spudfan
Ireland
Thumbs Up 1982 88" 2.25 diesel
Post #489289 6th Jan 2016 6:51pm
Page 2 of 2 <12
