Home > Maintenance & Modifications > school boy error....
Caterham
So what have I gone and done?
An oil change......very easy you might think?
Normally I would agree only this time I've gone and done it without first filling the oil filter first!
So who's the answer?
Post #282791 16th Nov 2013 9:34pm
T1G UP
take the oil filter off and put some oil in it!
Post #282793 16th Nov 2013 9:36pm
Lou Sparts
I never fill the oil filter first ! have i been doing it wrong all these years ? 2005 Td5 90 XS
Steve
Post #282794 16th Nov 2013 9:38pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
same as above but when it comes to the fuel filter then I fill it up BM52
Post #282796 16th Nov 2013 9:42pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Not an issue! Just start it up and stop it right away a couple of times and the filter will fill up or just start it and let it idle until the oil light goes out. The Puma filter holds very little oil anyway so will fill quickly. Besides most garage mechanics when it isn`t their own car and on racing to meet manufacturers times to do a job aren`t going to bother prefilling the filter housing before hand anyway! Smile
Post #282798 16th Nov 2013 9:43pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I would fill the fuel filter before fitting but not the oil filter, just use a little clean oil on the rubber seal
Post #282799 16th Nov 2013 9:44pm
Caterham
Shocked
That's good to know.... ( clearly I don't have a clue Laughing )
Post #282801 16th Nov 2013 10:01pm
Lou Sparts
I,m With BM52 i always fill fuel filter before fitting as it save all that bleeding/purging procedure. 2005 Td5 90 XS
Steve
Post #282802 16th Nov 2013 10:02pm
dondiddy
Especially with the 2.4 Puma you must always fill the fuel filter before fitting it then start the engine and let it idle for a few minutes otherwise you have a pig of a job bleeding it without the special primer bulb that Landrover state you need. (Ask me how I know!) and thats even when I did fill the filter beforehand! Laughing
Post #282806 16th Nov 2013 10:11pm
Caterham
Will sort the fuel filter later today now I have some fuel in the jerry can. Having done the oil, oil filter and air filter...what a difference!! induction growl sounds so much more obvious and low speed pickup is so much quicker.
Old air filter looked well dirty (wish i'd left a mark on old filter before service) so I guess either the air filter has improved things or i've disturbed the wiring for the better?
Either way Very Happy
Post #282888 17th Nov 2013 2:44pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Sounds like the puma fuel bleeding process is more of a ball ache than the TD5 one, which was a complete doddle. Something like push pedal hold it for so long push again bla bla.
But nah, never bother with oil filter filling - not even on aircraft which hold 8 litres of oil, the 1st litre gets blown straight out the vent, half litre into the oil cannister after running it, then you're down to 6.5 already - ideal!
Oil system can sort itself out, fuel, not so much. 1998 110 300Tdi White Hard Top
Post #282996 17th Nov 2013 8:22pm
Cheshire110
Yes definitely make sure you don't get air in the fuel system.
No auto prime feature and no pump on the filter itself as some cars have.
Think this was the cause of my high pressure fuel pump failure not too long ago, although nothing was ever proven- was very weird Cheers, David
Post #283009 17th Nov 2013 8:36pm
x-isle
Don't forget to fill the air filter with air when you fit it too!. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #283137 18th Nov 2013 9:43am
Caterham
Shocked
damn....can I use my track pump....... Rolling with laughter
Rolling with laughter Thumbs Up
Post #283147 18th Nov 2013 10:29am
Martin
Site Admin
Rolling with laughter  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #283150 18th Nov 2013 10:57am
