Home > Technical > Defender Bulkhead seal
submarinealan
Looking for advice planing on changing the bulkhead seal on a landcover defender 90 year 2000. Is replacing the seal straight forward or is this i bigger job than i think.
Does anybody have a link for this job.
Many Thanks
Post #488486 4th Jan 2016 3:29pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Which seal? There are many on the bulkhead. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #488487 4th Jan 2016 3:31pm
submarinealan
the one below the windscreen Very Happy
Post #488489 4th Jan 2016 3:33pm
Mash
It is an easy job, there is a row of bolts holding the roof on, bolts pass through the screen frame into captive nuts in the roof (a nut welded to a steel plate so do move around when re-installing) then remove the wiper arms and the hinge brackets, also remove the two trim sections one either side of the screen and ensure any cables running up them are clear. Remove door seals and then loosen off the roof retaining bolts that run along the rear tub to give you a little more clearance and it's good to lift out.
Once it's all back in its down to your eye to line it up, just do up the hinge bolts slowly and equally to get it to sit correctly. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #488495 4th Jan 2016 3:54pm
submarinealan
Many Thanks
Post #488512 4th Jan 2016 5:00pm
It surprised me that the roof was placed on with the windscreen already attached
Post #488575 4th Jan 2016 8:27pm
miker
I was idly thinking about this job the other day. Would another method entirely be to cut out the foam seal, clean it all up then sikaflex/tigerseal the gap?
Post #488613 4th Jan 2016 9:33pm
Happyoldgit
Lots of people wait for a dry spell, clean the joint and then apply a bead of sealant over the top, I've seen dealers do this too. Removing the dummy hinge blocks makes it easier to get a clean run of sealant. The joint is a poor design and is hit and miss even with a new bit of closed cell foam in between the frame and bulkhead. Steve.
http://forums.lr4x4.com
Post #488645 4th Jan 2016 10:37pm
submarinealan
What silicon would you recommend ? I'm thinking Captain Trolleys crack sealer. Laughing
Post #488670 4th Jan 2016 11:17pm
Screbble
I wouldn't mind a set of those wing/panel protectors now that they're surplus to requirement Thumbs Up
As for the silicon/sealer - Silkaflex 291i or 292i?
Has anyone bedded the closed cell foam strip on sealant?
Post #488700 5th Jan 2016 12:34am
Giby_off
Bulgaria 2012 Defender 110 Puma 2.2 SVX Station Wagon Havana
Does anyone have pictures from those bolts - "here is a row of bolts holding the roof on, bolts pass through the screen frame into captive nuts in the roof" and "then loosen off the roof retaining bolts that run along the rear tub" I am trying to figure out the steps I need to perform.
Post #496529 26th Jan 2016 11:10am
They are Screw, Flanged Head, M6 x 25mm and there's 6 of them that go into nut plates:
Items 6 & 9 below:
Post #496578 26th Jan 2016 1:05pm
Giby_off
Thanks. Those are the bolts connecting windscreen frame and the roof.
Which are those mentioned as roof retaining bolts that run along the rear tub?
I found this link is very useful
http://eastcoastrover.com/100top.html
Post #496709 26th Jan 2016 6:33pm
Cake
Jut to add my 2 pence - I had my seal replaced while having the screen corrosion sorted and it leaked.
In the end I purchased some 291 Sikaflex and sealed it along the outside - water tight now!
You hardly notice it along there - even the foam gasket is visible so no real difference in the end.
Post #499891 3rd Feb 2016 1:44pm
Happyoldgit
^^^Yup, as long as there's no corrosion to be dealt with that's the standard and permament fix. Steve.
Post #499932 3rd Feb 2016 3:47pm
