Anyone notice the clamping kit used on the final windscreen:
Click image to enlarge Click image to enlarge
3rd Feb 2016 3:10pm
Giby_off
What I did is:
- removed the original windscreen and the seal
- I found out that the left corner is wet and there is i little bit mud also
- cleaned out everything
- sealed with polyurethane for windscreen by filling the external seal channel with it
- after we put the windscreen back we decided not to clean immediately the polyurethane which went out of the seal and leave it for the next day
- the next day I tried to remove it but with no success because it removed the paint from the windscreen frame. It was not too much so I decided I could leave with it.
I do not know how flexible is the connection between the windscreen and frame and I am afraid a bit that it could cause windscreen damage.
Next time when I need to remove the windscreen I shall destroy it. I prefer this then to have constant leaks from there.
