Home > Maintenance & Modifications > Modifying heated seat wiring?
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Hi All
So after a couple of mishaps in the flooding whilst out on response work, I flattened my battery and didn't get chance to really top it up properly. I was using the heated screens and seats all the time to keep things warm and demisted for the best part of 48hrs in a row.
Does anyone think it would be possible to disconnect the front heated screen and heated seats from the vehicle battery and onto a second battery. Would it be as simple as pulling the load feed from the relay housing and rerouting it?
cheers North Cumbria Search and Rescue - Team Leader
Post #487366 31st Dec 2015 8:49pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Just install a split charge system otherwise how do you charge the secondary battery?? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #487393 31st Dec 2015 10:12pm
DuncanS
Thats the plan lol. Got all the auxiliary systems going to be run off the second battery, but want to take the heated seats off the primary battery and onto the secondary so that if I'm parked up and not doing much I can't kill the main battery. I could install a new loom from FCX but I don't want that cost. North Cumbria Search and Rescue - Team Leader
Post #487394 31st Dec 2015 10:17pm
The FCX kit is well worth the cost, easy fit too.
Post #487397 31st Dec 2015 10:38pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Hi there,
Have a look at the wiring diagram in this thread and it appears to be an easy project.
http://www.defender2.net/forum/topic8759-45.html
Steve
Post #487400 31st Dec 2015 10:42pm
DuncanS
Interesting. Cheers steve. Just wondering if anyone thinks they have some form of timer circuit? Mine seem to go off after a short while and then won't turn back on for a longer period. Don't know if thats a 2.4TDCi thing? North Cumbria Search and Rescue - Team Leader
Post #487401 31st Dec 2015 10:45pm
Martin
Site Admin
Are you leaving the vehicle parked up with the engine running or not? If not running, ignition on or off?
The heated screen does not operate with the engine off. Heated seats do not work with ignition off.
Depending on how you normally leave the vehicle, you may only need to rewire the seats.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #487402 31st Dec 2015 10:46pm
pj2106
If your on a split charge it doesn't really matter where they are connected too
You will only have to link batteries if main gets low 2008 110 2.4 XS Utility (Hagrid)
Post #487403 31st Dec 2015 10:46pm
Martin
Site Admin
No timer on them, no. What you are experiencing is the thermal switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #487404 31st Dec 2015 10:48pm
DuncanS
Martin, Thanks for the heads up on the heated screen. Don't need to worry about that one then (assuming front and rear are the same as its an XS) and possibly just the seats.
cheers
EDIT: Thermal switch, that'll be the offending item. So the next question is where is the switching done from the switch itself to the main seat? Would it perhaps be easiest to put some new connectors on the seats and use the feed to wire into a relay and then pull a new hard line in to run the load of the seats? North Cumbria Search and Rescue - Team Leader
Post #487406 31st Dec 2015 10:50pm
Martin
Site Admin
Ah the rear screen is active with the ignition on, so even with engine off.
Definitely no timer on the heated seats, you can see yourself from the wiring diagrams.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #487407 31st Dec 2015 10:54pm
DuncanS
Happy days. Just to clarify, is that diagram (supposedly from a TD5?) the same as a TDCi? Now just need to work out what connectors they are. Bah. Got to get the wing connectors as well at some point. North Cumbria Search and Rescue - Team Leader
Post #487408 31st Dec 2015 10:57pm
Hairysteve
PM me your email address and will send you the electrical diagrames Thumbs Up
Post #487409 31st Dec 2015 11:06pm
Hairysteve
Post #487410 31st Dec 2015 11:09pm
Cupboard
I might have missed something obvious here, but why don't you just leave the engine running when you've got the ignition on?
Simple way to not flatten the battery is to only use electrical things when then engine is running, the heating works much better that way too Wink
Post #487447 1st Jan 2016 9:54am
