![]() | Home > Maintenance & Modifications > Modifying heated seat wiring? |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Just install a split charge system otherwise how do you charge the secondary battery?? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Thats the plan lol. Got all the auxiliary systems going to be run off the second battery, but want to take the heated seats off the primary battery and onto the secondary so that if I'm parked up and not doing much I can't kill the main battery. I could install a new loom from FCX but I don't want that cost. North Cumbria Search and Rescue - Team Leader
The FCX kit is well worth the cost, easy fit too.
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Hi there,
Have a look at the wiring diagram in this thread and it appears to be an easy project. http://www.defender2.net/forum/topic8759-45.html Cheers Steve |
Interesting. Cheers steve. Just wondering if anyone thinks they have some form of timer circuit? Mine seem to go off after a short while and then won't turn back on for a longer period. Don't know if thats a 2.4TDCi thing? North Cumbria Search and Rescue - Team Leader
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
Are you leaving the vehicle parked up with the engine running or not? If not running, ignition on or off?
The heated screen does not operate with the engine off. Heated seats do not work with ignition off. Depending on how you normally leave the vehicle, you may only need to rewire the seats. ![]() ![]() |
If your on a split charge it doesn't really matter where they are connected too
You will only have to link batteries if main gets low 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
No timer on them, no. What you are experiencing is the thermal switch. ![]() ![]() |
Martin, Thanks for the heads up on the heated screen. Don't need to worry about that one then (assuming front and rear are the same as its an XS) and possibly just the seats.
cheers EDIT: Thermal switch, that'll be the offending item. So the next question is where is the switching done from the switch itself to the main seat? Would it perhaps be easiest to put some new connectors on the seats and use the feed to wire into a relay and then pull a new hard line in to run the load of the seats? North Cumbria Search and Rescue - Team Leader |
Ah the rear screen is active with the ignition on, so even with engine off.
Definitely no timer on the heated seats, you can see yourself from the wiring diagrams. ![]() ![]() |
Happy days. Just to clarify, is that diagram (supposedly from a TD5?) the same as a TDCi? Now just need to work out what connectors they are. Bah. Got to get the wing connectors as well at some point. North Cumbria Search and Rescue - Team Leader
PM me your email address and will send you the electrical diagrames
I might have missed something obvious here, but why don't you just leave the engine running when you've got the ignition on?
Simple way to not flatten the battery is to only use electrical things when then engine is running, the heating works much better that way too ![]() |
