![]() | Home > Maintenance & Modifications > Entreq snorkel |
thor44 Member Since: 18 Sep 2015 Location: Ahrntal, S�dtirol Posts: 128 ![]() ![]() |
@WC90: awesome looking ninety!
![]() ![]() Back to the topic: Do you mean they actually create a hearable sound? I remember from driving in summer and windows down, that there is in fact coming a sound from the air intake on higher rpms. Does a snorkel amplify that to a level, that is hearable all the time? Because that would be awesome! ![]() |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Yes they are the 255 /85 MT�s. I have Koni Heavy Track Raids, 50 mm raised Trailmaster springs - standard duty fronts, heavy duty rear - as I tow a 3500 Kg trailer. It does have a slightly wedged stance, when lightly loaded, but not as much as the posted picture suggests. Propshafts, radius arms and bumpstops are uprgraded too, and it drives really well, even without a trailer:-).
Back to the snorkel! The motor is stock, but I have a K&N filter (although I doubt this is a factor). At cruising speeds there isn�t much difference, but on acceleration, and deceleration, there�s a combination of hissing and throaty sucking noises that are worth turning the radio off to listen to. Occasionally just after pulling away, and when changing up a gear it makes an amusing hiccup sound, just briefly. it�s not quite sidedraught Webers on an Alfa Romeo, but pretty good for a truck! ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons Last edited by Wild Card 90 on 27th Nov 2015 4:34pm. Edited 1 time in total |
Thanks
Go for it. Entreq�s products are top, and you�ll enjoy the sound effects from the snorkel.... 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
As promised, a picture of the plumbing for the Nakatakenga snorkel. It is basically just a constant diameter flexi-pipe all the way from the snorkel to the air filter. The tube connecting the side intake to the heater box is similarly simple. The original plumbing that it replaced looks way more complicated.
If it makes a difference to the performance, I really don�t know. Stephen ![]() Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Would be nice if one could buy the side scoop as a single item.
I spoke to Peter at Naka, and he said they can supply the scoop seperately. It is their own product. He was curious to know why, and I couldn�t give him the answer.
Sadi, do you already have a wing top snorkel? 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
Hi Wild Card,
I would like to feed a bit extra fresh air into the side facing air intake - on the RHD model. Thank you very much for your enquiry to Naka - I already purchased quite a bit from them via site sponsor 4x4 Overlander - and will watch the involved sites to see when the article appears. Just heard that my long awaited Heritage arrived at the dealership today - and was sent for a few off-road goodies to be installed ... Thanks again. |
Hi guys,
after Santa finally brought me my long awaited snorkel I was now able to fit it and take it on a test drive. First of all I have to say, that the quality of the Entreq stuff is really extraordinary. Fitting was a piece of cake and everything came into place quite nicely, especially after paying attention to some special tips and tricks Mr. B�cking from Entreq Engineering told me earlier by mail. The quick and easy support directly from the manufacturer was surely a plus for the Entreq snorkel. As the fitted snorkel looked already great on my Landy I couldn't wait to hear the new hissing sound Wild Card 90 told me about. And after driving up the nearby mountains I can definitely confirm the new sound coming from the big black tube. No empty promises in this regard. Thanks WC90! ![]() Now I'm already longing to know how much better it has to sound on warm summer days when the Defender has already been gleefully sucking in all the air it was able to get hold of. ![]() At the end a picture of my Landy with the fitted snorkel on top of our unfortunately snow free mountains (apart from the ski resort in the top left corner, of course). Have some nice holidays and a happy new year! ![]() ![]() Click image to enlarge |
Thor, it looks
![]() Happy you have been able to first hand experience that Entreq quality indeed is in a league of its own, often copied, rarely equalled. Question. Did you just fit the Entreq "schnorchel", or did you also install Olaf's "Airflow-Kit II" which makes it a real waterproof installation? And which, very importantly, provides an unrestricted airflow to the airfilter box, as opposed to the standard Puma air intake pipe which is shockingly narrow at some point. Here is the link to what I mean, which works for both Puma 2.4 and later 2.2. http://www.entreq.de/expedition-gear/erhoh...-tdci.html I have the Airflow Kit II in my 2016 upgrades planning together with other (brand new) Entreq reliability items. Won't go as far as the schnorchel myself as personally I won't have any benefit from that, but the Airflow Kit II should further optimize the air mass supplied to the turbo which then will further slightly improve the compressed airflow to my already installed Entreq intercooler and SS pipes. Ultimate goal is to maximise the volume of as cool as possible air mass supplied to the engine, which should optimise the combustion process and keep summer engine temperatures under control when calling for power. I guess I may gain a few HP/Kw in the process, that will be my kind of "tune without a tune" then. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks Eric!
I fitted the entreq airflow kit(s) - the RAI may be in the wish list next year
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Eric - if the turbo is matched to the current "restricted" trunking, then I'm not sure how you can gain anything; or are you saying that jlr over-spec'd the current turbo and there is headroom for improvements. Any actual figures you have would be useful to share. |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
For purely functional purposes, there are very few, if any, snorkels that can beat the Southdown. The pipe passes through the top of the wing and a flexi pipe joins it in the engine compartment. Then straight to the filter.
Only two connections (either end of th single flexi pipe) between the filter and the top of the windscreen. The filter needs to be sealed if using it underwater as the body is not waterproof, otherwise a filter can be fitted to the top of the snorkel in place of the rotational head. |
