Home > Maintenance & Modifications > Help with a switch
90def
2011 Defender 90 Puma 2.4 HT Epsom Green
Help with a switch
Need some help please with a light bar switch .. It's got 2xdc pins ...12v\24v.. and onepin 20a\10a ...what pins do I use and what are they for cheers Phil
Post #485469 26th Dec 2015 8:53am
mikeh501
It's just a switch? Put it inline on your positive feed. It doesn't matter which terminal.
The 12/24 and 20/10 is just a rating for the switch at either 12 or 24 volts. Only thing I'd check is whether your lightbar is below 20 amps.
Post #485477 26th Dec 2015 9:36am
rallysteve
Does it illuminate or have a built in 'teĺl tale' led? If so one terminal will be an earth for the warning lamp/illumination. One will be the feed from positive (fused) supply and the third to the light bar.
If the switch has no illumination/warning lamp, then it will just be a changeover and the centre terminal will be from your supply and either end to the light bar depending one which way up you mount the switch.
Post #485481 26th Dec 2015 10:05am
