rallysteve
Does it illuminate or have a built in 'teĺl tale' led? If so one terminal will be an earth for the warning lamp/illumination. One will be the feed from positive (fused) supply and the third to the light bar.
If the switch has no illumination/warning lamp, then it will just be a changeover and the centre terminal will be from your supply and either end to the light bar depending one which way up you mount the switch.
Steve 02' 110 TD5 Double Cab Rebuild Thread
26th Dec 2015 10:05am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
