Home > Tdi > Transfer box swap.. what else do I need
Mean Green
I am going to swap the LT230 in my 200tdi 90 for one from a disco to get the 'better' gearing.
Just wondering if anyone else has done it - other than the 'box what else will I need? Gaskets, seals etc. I want to have everything to hand before I start.
Post #483875 20th Dec 2015 10:28am
grafty99
A tube of rtv sealant, transfer box oil and new nuts and bolts for the props. Might be worth putting new handbrake shoes in whilst you're there too? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #483878 20th Dec 2015 10:37am
Retroanaconda
Assuming the seals etc. in the new box are ok...
Mounting rubbers (if required)
Propshaft nuts
Might need to sort handbrake mount
I would get a new input seal in case you damage it putting the box on
Cross-drilled input gear if not already fitted (would be silly to put a box without one on)
Oil
Would be a good start.
Post #483879 20th Dec 2015 10:38am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
When I had my one done they changed over the speedo drive. I believe they are different colours and can be a pain to remove. Also something to support it when removing/ installing the transfer box. I think it is a great improvement and is quiter does not rattle as much.
Post #483952 20th Dec 2015 3:19pm
jst
propshaft tool will speed the job along nicely Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #484031 20th Dec 2015 9:01pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
What for?
Post #484061 20th Dec 2015 10:11pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
If you can knock up a support bracket (in steel or timber) it's a bonus.
I made one that I then strapped onto the Transfer Box and made the job pretty easy.
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #484089 20th Dec 2015 11:31pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I cut some long (about 6") pieces of threaded bar,to make lining it up when sliding it on to the input shaft easier.
Its a heavy lump to hold in position on your own.
Marc
Post #484109 21st Dec 2015 7:13am
grafty99
I Like Old Skool wrote:
What for?
Assuming you want the sump off to clean it out/inspect before fitting again assuming its not a new one... 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #484133 21st Dec 2015 10:03am
Timo
Canada 1984 Defender 110 300 Tdi SW Alveston Red
That is brilliant! Series II in pieces
1984 Defender 110 (3.5l V8 now 300TDI)
Post #488720 5th Jan 2016 4:25am
Mean Green
Propshaft nuts
Oil
What do you need to do with the handbrake? Is it a different cable?
Post #490933 11th Jan 2016 11:43am
Retroanaconda
Sometimes there's a different mount for the handbrake on a Disco box to the Defender, so it has to be changed over. If I recall correctly this may mean drilling/tapping the mounting holes into the transfer case (the bosses for this are already present).
Not sure if this applies to later Defender boxes which have the direct cable entry handbrake though.
Should be fairly easy to tell by just looking at the two boxes.
Post #490949 11th Jan 2016 12:34pm
Martin
Site Admin
If you are using a Discovery 2 transfer box you will need to swap over the entire rear housing as there is no speedo drive hole.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #490962 11th Jan 2016 1:39pm
