![]() | Home > Tdi > Transfer box swap.. what else do I need |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
A tube of rtv sealant, transfer box oil and new nuts and bolts for the props. Might be worth putting new handbrake shoes in whilst you're there too? 2002 90 Td5 Station Wagon
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
Assuming the seals etc. in the new box are ok...
Mounting rubbers (if required) Propshaft nuts Might need to sort handbrake mount I would get a new input seal in case you damage it putting the box on Cross-drilled input gear if not already fitted (would be silly to put a box without one on) Oil Would be a good start. |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
When I had my one done they changed over the speedo drive. I believe they are different colours and can be a pain to remove. Also something to support it when removing/ installing the transfer box. I think it is a great improvement and is quiter does not rattle as much.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
propshaft tool will speed the job along nicely Cheers
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 859 ![]() ![]() ![]() |
What for? |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
If you can knock up a support bracket (in steel or timber) it's a bonus.
I made one that I then strapped onto the Transfer Box and made the job pretty easy. ![]() Click image to enlarge -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 583 ![]() ![]() ![]() |
I cut some long (about 6") pieces of threaded bar,to make lining it up when sliding it on to the input shaft easier.
Its a heavy lump to hold in position on your own. Marc |
Assuming you want the sump off to clean it out/inspect before fitting again assuming its not a new one... 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 ![]() ![]() ![]() |
That is brilliant! Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
What do you need to do with the handbrake? Is it a different cable? |
Sometimes there's a different mount for the handbrake on a Disco box to the Defender, so it has to be changed over. If I recall correctly this may mean drilling/tapping the mounting holes into the transfer case (the bosses for this are already present).
Not sure if this applies to later Defender boxes which have the direct cable entry handbrake though. Should be fairly easy to tell by just looking at the two boxes. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6693 ![]() ![]() ![]() |
If you are using a Discovery 2 transfer box you will need to swap over the entire rear housing as there is no speedo drive hole.
