![]() | Home > Maintenance & Modifications > TD5 Oil Filter Removal |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Which one? I assume you mean the static one - if so its possible to remove it from behind the turbo with a filter strap from above
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 60 ![]() ![]() ![]() |
Thanks Grafty, are you saying that I should be able to access the filter from below without removing the tray?
Do you mean this one
![]() http://forums.lr4x4.com/index.php?showtopic=26224 |
No, over the near side wing with a filter strap. A tip would be to loosen it with the strap then put a plastic bag such as a sandwich or bread bag round it and spin it off by hand. Then complete the Mensa test by extracting the said filter from behind the downpipe and heat shield. It can be done
ahh found it now thanks, didn't realise it was that high up. Looks like it is going to be a pig to remove, old Tdi 200 was a lot easier...
Many thanks guys. |
They are normally not too bad, I did have one that needed removal of the turbo in order to get it off though. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Treebeard Member Since: 27 Jun 2012 Location: Forest of Dean Posts: 40 ![]() ![]() ![]() |
As a last resort, hammer an old screwdriver through it if you can't get enough grip with a strap or chain. Best done on someone else's drive.
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
When you come to replace it there is a shorter version available that can make things a bit easier. Personally I've never had a problem with the standard. Island 4x4 sell them.
this can be helpful
http://www.paddockspares.com/td5-oil-filter-wrench.html |
I've got a strap so will give that a go at the weekend.
Thanks again guys. |
Don't forget the plastic bag, can make the experience a little less messy
well I failed miserably, can't get strap on and to weak to remove by hand.....
![]() Not sure what I'm going to do now. ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2272 ![]() ![]() ![]() |
You should be able to get the filter strap on. It can be a bit awkward, and you can only get a slight movement, but it should do it. I recall it can take a few attempts to get it moving. They are often unnecessarily over tightened.
![]() Don't forget the plastic bag once it's loose - great advice given to me by JWL ( ![]() I'm not sure if you can get enough clearance, but the hammer and screwdriver might get it started - but take care you don't hit anything else in the area. The proper wrench is really good. I'd also recommend the shorter filter if you wish to make things a little easier in the future. ![]() Don't give up - sometimes walking away, grabbing a brew, and having another go later with a different mindset makes all the difference! That works for me anyway..... ![]() |
Hammer the screwdriver right through the side and then around the side of the core - you'll have it off in seconds. Put an old tarp or big tray underneath.
