Home > Maintenance & Modifications > TD5 Oil Filter Removal
landiedave
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Hi, can someone advise me how to gain access to the oil filter on my TD5, do I need to remove the under tray?
Apologies for my muppetry Embarassed
David
Post #483916 20th Dec 2015 1:19pm
grafty99
Which one? I assume you mean the static one - if so its possible to remove it from behind the turbo with a filter strap from above Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #483918 20th Dec 2015 1:21pm
landiedave
Thanks Grafty, are you saying that I should be able to access the filter from below without removing the tray?
Post #483919 20th Dec 2015 1:33pm
dorsetsmith
Post #483923 20th Dec 2015 1:42pm
JWL
No, over the near side wing with a filter strap. A tip would be to loosen it with the strap then put a plastic bag such as a sandwich or bread bag round it and spin it off by hand. Then complete the Mensa test by extracting the said filter from behind the downpipe and heat shield. It can be done Thumbs Up
Post #483924 20th Dec 2015 1:45pm
landiedave
ahh found it now thanks, didn't realise it was that high up. Looks like it is going to be a pig to remove, old Tdi 200 was a lot easier...
Many thanks guys.
Post #483934 20th Dec 2015 2:22pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
They are normally not too bad, I did have one that needed removal of the turbo in order to get it off though. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #483936 20th Dec 2015 2:27pm
Treebeard
United Kingdom 2005 Defender 110 Td5 CSW Chawton White
As a last resort, hammer an old screwdriver through it if you can't get enough grip with a strap or chain. Best done on someone else's drive.
Post #484267 21st Dec 2015 9:32pm
grumpy old git
When you come to replace it there is a shorter version available that can make things a bit easier. Personally I've never had a problem with the standard. Island 4x4 sell them.
Post #484272 21st Dec 2015 9:37pm
dorsetsmith
Post #484276 21st Dec 2015 9:41pm
landiedave
I've got a strap so will give that a go at the weekend.
Thanks again guys.
Post #484469 22nd Dec 2015 2:22pm
JWL
Don't forget the plastic bag, can make the experience a little less messy
Post #484481 22nd Dec 2015 3:05pm
landiedave
well I failed miserably, can't get strap on and to weak to remove by hand..... Embarassed
Not sure what I'm going to do now. Sad
Post #485574 26th Dec 2015 5:57pm
Screbble
You should be able to get the filter strap on. It can be a bit awkward, and you can only get a slight movement, but it should do it. I recall it can take a few attempts to get it moving. They are often unnecessarily over tightened. Neutral
Don't forget the plastic bag once it's loose - great advice given to me by JWL ( Thumbs Up ) when I first changed the filter.
I'm not sure if you can get enough clearance, but the hammer and screwdriver might get it started - but take care you don't hit anything else in the area.
The proper wrench is really good.
I'd also recommend the shorter filter if you wish to make things a little easier in the future. Thumbs Up
Don't give up - sometimes walking away, grabbing a brew, and having another go later with a different mindset makes all the difference! That works for me anyway..... Very Happy
Post #486076 28th Dec 2015 12:32am
Treebeard
Hammer the screwdriver right through the side and then around the side of the core - you'll have it off in seconds. Put an old tarp or big tray underneath.
Post #486254 28th Dec 2015 5:07pm
