Home > Maintenance & Modifications > Passenger grab handle
Petronius4
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Hi all
I'm looking to fit a passenger 'grab handle' in the side roof space above the front NS door - I'm sure I've seen these fitted in some higher spec Defenders?
Anyway my challenge is how to fix it in place - I have a standard vinyl headlining but am assuming that there needs to be a fixing point strong enough to weight-bear someone using it to 'pull themselves in' to the car.
Anyone know how these things attach? Please don't say I have to take the roof lining out...
Thanks. -------------------------------
👲🏻 1986 ex-Military 90 NAD 2.5 Soft Top. Sold
🇬🇧 2015 Defender 90 - Ripon Landrover Heritage 006
Post #483404 18th Dec 2015 6:29pm
grafty99
I don't think they have ever been available as a standard fit. The only place strong enough would be the inner roof gutter where the fir tree clips hold the headlining up Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #483415 18th Dec 2015 7:10pm
g-mack
on my old tdi 110, the 2nd row grab handles are self tappers through the roof gutter. seems ok but wouldn't like to do chin ups off it Very Happy can't see why you couldn't do something similar up front! My 109 thread
my youtube channel
Post #483466 18th Dec 2015 8:40pm
rallysteve
There are some funny plastic spacers that are needed. The handles screw into the spacers and through the internal gutter. I bought some of the spacers myself but the handles were quite expensive. If fitting from scratch you could try RRC or disco ones though. I have seen some handles fitted to the a pillar too using the existing trim mounting screws 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #483518 18th Dec 2015 10:33pm
X4SKP
After many years of intending to fit a Front Passenger Grab Handle...I've decided to tick this off the to do list
My plan is to fit a Standard LR Grab Handle... to the Passenger Front Near Side...my Wife still goes to 'air grab'
what isn't there (and should be really) so before we set off on our adventures this year... this is getting sorted out
I have 4 (JPC5640LNF) Grab Handles fitted already in my 90... 2 at the rear over the door, and 2 on the sides, as an aid to the rear seated passengers
Positioning this Handle against the Roof Liner at the Front, appears to set up the fixing positions directly in line with the pre-existing 'Christmas Tree' push fasteners...presumably these go into a receiving 'channel' above...
Is this correct... Question
Does anyone have any photos of this area...with the lining out... Question
Has anyone else done this... Question
My plan is to insert X4 M5 Rivnuts if the inner metalwork 'channel' will accept this, to secure the Handle
I can semi-remove this area of head lining to check...but wondered if someone has been there before me... Question
Thanks... SKIP
Post #617941 19th Apr 2017 5:35pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Subscribed..
Found some pics here:
http://www.defender2.net/forum/topic38378-15.html
Would love to watch your progress and results please - even male passengers often complain about the absence of a "grabhandle".
Post #617947 19th Apr 2017 6:24pm
X4SKP
Hello Sadi... Thumbs Up
I half remembered this thread...and it's going in the same general direction (thanks)
Looks promising too...just need to understand the proportions / details of this area...
I will definitely post my solution...Yes you are right too... a Unisex Gab Handle Idea SKIP
Post #617949 19th Apr 2017 6:35pm
VeeTee
Netherlands
Saw this somewhere recently. Seems a nice solution and a good way to adapt for the existing holes in in the inner gutter.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #617955 19th Apr 2017 6:55pm
X4SKP
Thanks VeeTee
Interesting...if there is a continuous 'channel' here (underneath the head lining) then I would create new fixing positions for the Grab Handle, at the locations required.
The profile of the longer element on your example looks to allow lateral adjustment / positioning of the Handle and
its shape / cross section looks to go some way in ensuring a 'stiff' element, and therefore preventing the Handle from
flexing this part away from the roof lining.
All looks positive so far... SKIP
Post #617977 19th Apr 2017 8:34pm
mk1collector
Ther is a channel above there, I'd use nuts bolts and washers for a strong fixing and the caps should still cover them. Ray
My build thread
Post #617980 19th Apr 2017 8:45pm
VeeTee
Netherlands
^ The inner gutter (to where the roof lining is attached) is strong enough to attach the c-section rail to. You could even use the existing holes where the fir trees are. I intend to do so, using rivnuts.
(... and so another little project is born while browsing this forum. It never ends... Rolling with laughter ) Cheers, Vincent
MySite
Post #617984 19th Apr 2017 8:48pm
X4SKP
mk1collector wrote:
There is a channel above there...
... Thumbs Up thanks mk1collector SKIP
Post #617992 19th Apr 2017 9:02pm
X4SKP
Hello All
Having now fixed a Passenger Grab Handle, a few photo's of how I went about it...
I decided to work on the direct fixing line 'visible' for the head lining, so positioned my fixing points
in line with the two fir tree plastic fasteners at roof level above the passenger seat.
The logic was to replicate the space required for fixings within the 'hidden' aluminium channel, without taking
the head lining out to confirm the exact 'arrangements'.
I used a Land Rover 'standard' Grab Handle, and off set this inwards to ensure clearance between the top
profile of the door and your hand when 'grabbed'. The profile of the handle itself also orientates the Handle
further inwards, when mounted in this position.
The down side...potentially... of this arrangement is that it sets up an obstetrical for head clearance
when climbing in an out, so I had a plan to try this first, with a plan B position, of moving the Handle both further inwards and rotating it by around 90 degrees up into the 'roof void'...so completely above door line, and similar to both the existing side and rear handle positions.
My wife however (who is 5 foot...nothing) has tried plan A, and prefers it here (although the alternative has not been tried)...saying it would feel like i'm reaching up too far if it was higher...so here it's staying...I'm 6 foot (and know its there and getting in and out seams OK so far...you can even use it to aid getting in and out, which my mother in her mid 80's found a + too).
So...
Inside (level with lower edge of door frame)
Outside (lower than roof line, and an aid to get both in and out)
Positioned 'inset' to 'corner profile' of roof lining (gives clearance with door when shut and handle in use)
OEM LR Grab Handle (with modified, additional mounting brackets, 3.0mm aluminium)
X4 fixing positions through head lining (in line with head lining fixings, M5 Rivnuts used,
with the head lining material 'core' removed so the Rivnuts are seated directly on the hidden Aluminum
Channel...in case the head lining ever needs to come out)
Grab Handle mounting brackets (with neoprene cushion to protect alcantara head lining,
and space washers to sit within head lining thickness, so as not to crush the head lining)
As with most things in 'Defender Land' even a simple modification can be time consuming,
this took most of day so complete...I really didn't want to mess up my 'upgraded' head lining.
The rivnuts and 'short' off set brackets hold the Grab Handle really firmly, the only flex is within
the Handle itself...so...so far its OK
Wife very pleased to have (what shes always wanted) her JFC Handle... Exclamation SKIP
Post #622658 8th May 2017 2:50pm
bankz5152
Looks good!
I did one here as well, standard fender door handle for now, may replace with a nice leather one in the future.
Post #622683 8th May 2017 4:08pm
Chopperone
Bankz;
Does the standard door handle pick up existing screw holes for fixing points OR did you do something else?
Tia
Guy May your life be like toilet paper ; long & useful.
Post #622801 9th May 2017 6:23am
