Home > Tdi > Rev Counter for 300tdi
schweps
Turkey 2005 Defender 110 300 Tdi HT Alpine White
Hi,
I found a genuine land rover rev counter which is normally used for normal diesel engines.
Do you think is it applicable for 300 tdi engines?
cheers.
Post #481389 11th Dec 2015 8:52pm
jst
td5 ones said td5 in the middle of them earlier ones didnt. i didnt know LR did a rev counter (52mm) for the tdi or any diesel vehicle of that age.
plug it into the w connector on an Alt and see! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #481424 11th Dec 2015 11:10pm
schweps
Yes you're right. It's not a genuine LR Product but what I mean, it was not adapted by the owner. So as you've mentioned, easiest way is to plug it into the alternator. But I need to buy it first, cause it is away from where I live. What I need to know is, if the rev counters used at normal diesel engines are interchangable with turbo engines? Without any tune up with an ossiloscope.
Cheers.
Post #481470 12th Dec 2015 9:46am
Mo Murphy
Yes providing the rev range on the dial is appropriate to your vehicle. All it does when connected to the alternator is count pulses as the alternator rotates, it doesn't matter if it's non turbo or turbo.
VDO make a nice reliable rev counter that should match well to your existing gauges.
HTH
50 Shades of Pennine Grey
Post #481500 12th Dec 2015 11:45am
schweps
Thanks,
Post #481597 12th Dec 2015 7:31pm
nickhodgson
South African Spec 300tdi vehicles had a rev counter. So there is a genuine part available. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #481978 14th Dec 2015 11:25am
PaulMc
There is a 'Tdi' version of the Td5 style rev counter, which is for the RoW spec TD5 Defender that was factory fitted with a 300Tdi engine - its part number is - YAE100800
This rev counter is driven by the 'W' terminal on the alternator, and matches the TD5 gauges perfectly, in style and illumination.
It's not cheap though Shocked
http://www.brit-car.co.uk/product.php/9512...i_defender
There are a couple of places that list it a bit cheaper than Brit-Car.
. Paul.
Post #481994 14th Dec 2015 12:10pm
schweps
Hi again,
Does someone have the code number of appropriate vdo rev counter?
I'm a bit confused between these two statements from forums.
VDO 333-156 0-4000 rpm limit.
The VDO 52mm 0-5000rpm rev counter will work on either the V8 or 300TDi from 1996.
I Believe 0-4000rpm is not good for 300TDI, but I don't the others code no.
Cheers.
Post #482218 14th Dec 2015 9:31pm
schweps
Hi PaulMc,
It is so expensive Sad
Here I can buy complete dashboard from early '90's diesel engine for around 50£.
I'm not sure if it could work fine though.
Post #482227 14th Dec 2015 9:44pm
schweps
Hi again,
I bought a brand new 0-6000rpm vdo (WWG 333 035 017x)
My alternator is probably magnetti marelli.
Could someone please confirm that the screw shown in red circle is the W terminal.
Regarding the tachometer, it has three switches numbered as 1,2 and 3. Not like as 4,5,8 which refers to cylinder numbers. Default setting is #1 is on. Shall I keep it as it is?
Cheers and wish you all a happy new year.
Post #485588 26th Dec 2015 6:49pm
VeeTee
Netherlands
I'm not 100% sure, but I think you are right re the w-terminal.
Re the coding switches on the tachometer, I think #1 on is the (default) setting for a four-stroke petrol engine. For a diesel engine you have to set a code with the switches according to the number of impulses per revolution. I think #2 on, 1 & 3 off might work for you. See pages 3-10 and 3-11 :
http://www.mechanikadc.cz/wp-content/uploa...tional.pdf
And:
http://www.4x4community.co.za/forum/attach...1295261426
If you bought the tachometer brand new, didn't it come with a manual? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #485614 26th Dec 2015 7:49pm
schweps
Thanks for your reply VeeTee,
Unfortunately there was no instruction manual in the box.
But the document you've linked will be useful.
Cheers.
Post #485618 26th Dec 2015 8:09pm
schweps
Attached two different alternators seems to have additional small black box connections that I don't have.
Does anyone knows why?
Post #485642 26th Dec 2015 9:23pm
VeeTee
Netherlands
Probably an interference supression capacitor. Cheers, Vincent
MySite
Post #485648 26th Dec 2015 9:49pm
schweps
Do you think it depends on the model (capacity) of the alternator and applied by the manufacturer or a modification?
Post #485650 26th Dec 2015 10:03pm
