Home > Tdi > Rev Counter for 300tdi
Page 2 of 2 <12
VeeTee
Netherlands
I wonder if you really need one. They are used to suppress electronic interence what would hear on the car radio as a whining noise. Modern car radios have a built in suppression unit. I would test if you really need one, if you do have an interference on your radio you could fit one, in general a value of 1-3 microF is used. A car radio shop can advise further. Cheers, Vincent
MySite
Post #485668 26th Dec 2015 10:51pm
schweps
Turkey 2005 Defender 110 300 Tdi HT Alpine White
Now it is clear for me.
VeeTee, thanks for your all kind explanations.
Cheers.
Post #485743 27th Dec 2015 9:03am
schweps
With the help of the VDO document that VeeTee referred, rev counter is tested and it is working fine.
Terminal W was the bolt that I've circled and asked in earlier messages.
My crank pulley dia is 175mm, alternator pulley dia is 50mm.
According to the formula "i" is calculated as 175/50=3,5 and impulse, 6x3,5=21
From the table, switch 2 is selected and all cables connected temporarily.
Idling rev was around 750-800rpm and response seems ok to the gas pedal.
Cheers.
Post #485884 27th Dec 2015 5:56pm
VeeTee
Netherlands
Seems all OK to me. Cheers Thumbs Up Cheers, Vincent
MySite
Post #485912 27th Dec 2015 7:08pm
schweps
I'm a restless guy, I admit that.
At my calculation and while using the table I might have made wrong assumptions.
Like as; for the rpm column the numbers (4000, 6000 and 8000) I considered them as the dial limit of the rev counter.
But now I understand they are not. The rpm value refers to the max rpm of the alternator. Thanks god, they are both same for dial limit of the rev counter and max rpm of the alternator.
For the number "6" from the formula, I considered that as a constant value. But now I realized that it refers to number of pairs of poles. From the alternator data table above, "Field winding rotor poles" is given as 12. So when we call pairs, shall we divide it by 2 ? Or whilst it is three phase shall we divide it by 3 ?
If it shall be 12/2, then my assumptions are correct by chance.
Cheers.
Post #486137 28th Dec 2015 9:54am
VeeTee
Netherlands
Regarding the number of poles, you are correct, 12 poles is 6 pairs.
Why dou you think the 6000 refers to the max. rpm of the alternator? I think it refers to your first assumption, the scale of the rev.counter. Let me put it like this, if you have an alternator with same pulley dimensions and same number of poles, but other max. rpm, the frequency (pulses per second) at a given engine speed does not change. On the other hand, if you put in a tachometer with a different scale you have to adapt to the scale of the meter. Don't know if it sounds logic, but this is how I would think it works. Wink
Edit: if you look at the document in my first link, it says:
Quote:
Ist die Impulszahl (Impulse am Ausgang Klemme W der Drehstromlichtmaschine pro Umdrehung des Motors) bekannt, den Kodierschalter nach der Kodiertabelle einstellen
so they are talking about the number of impulses per revolution of the engine, not per revolution of the alternator... Cheers, Vincent
MySite
Post #486235 28th Dec 2015 4:01pm
schweps
I've googled too much about this and some how I had the impression that it should be the alternator's max rpm.
And when I pass through the vdo document, I noticed 3000rpm and 7000rpm scaled rev counters to support this impression.
But after your message I checked the document again and saw tables including those rpm's aswell (page 3-11) Smile
Since now I was focused on 52mm ones at page 5-11.
So you're right and every thing seems ok.
Cheers.
Post #486248 28th Dec 2015 4:54pm
VeeTee
Netherlands
Since it's both 6000 it does not matter for now, but I am always curious to know why it is or works the way it is... Wink
Cheers, happy driving! Thumbs Up Cheers, Vincent
MySite
Post #486261 28th Dec 2015 5:25pm
schweps
As long as there are impulse tables for 3000 & 7000rpm like below,
no doubt VeeTee, you are absolutely correct.
Post #486313 28th Dec 2015 7:46pm
Page 2 of 2 <12
