![]() | Home > Td5 > Sealing panels |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Had some wet carpeting in the load area left hand side next to the rear swing door next to wheel arch.
Previous owner or somebody backed into the rear and pushed the licence plate light assembly into the body panel about 5-10mm. Anyway...it pushed it just enough to open a seam between the panel and the stiffener corner piece that the tail and signal lamps attach to. Noticed the gap using a flashlight from the inside in a dark garage. I'm thinking of pulling the metal out a bit and sealing the seam with silicon from the inside. I thought I read on some other site that silicone is acidic and will attack the aluminum. Is this true? BTW....WTF is this sikaflex that everyone keeps talking about? Patrick |
Thanks Roel!
BTW.....are there and Land Rover breakers in southern Netherlands? Patrick |
sikaflex can be panted over . but silicone can not
sika also make different types seal and bonding for car, boats, planes |
Understood and makes sense..I found sikaflex on a number of websites for construction sealing. Around windows brick, siding and flashing and says it can be painted over. Is this something people use to seal gaps in the defender floor panels...etc?
I think for my application, I can go wth silicone from the inside for now and keep looking for sikaflex. Thanks to all Patrick |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I use Sikaflex on my Land Rover. I use it for sealing gaps, for wet fixing nuts/bots and any other sealing / adhesive needs.
Having seen silicon peel away when subject to harsh & wet conditions I wouldn't bother. Get Sikaflex and the job is done for good... ![]() Cheers Simon |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Tigerseal is also good. Wouldn't bother with silicone.
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Do it once and do it right.....Sikaflex it !
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
If you choose silicon sealant use NEUTRAL one, not an acidic type. But sikaflex is probably a better solution, it is not silicon based. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
Which one do you guys use?
Everyone just says "Use Sikaflex" which one? 3 Landrovers |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 409 ![]() ![]() ![]() |
+1 Sikaflex
I hadn't realised there were different types other than colour variations.
I've used this in the past and have been happy with the results. I was sealing the bulkhead / windscreen frame hence going for the black option. http://www.screwfix.com/p/sika-sikaflex-eb...00ml/79299 |
Ok....I'm living very close to the border of Germany, Netherlands and Belgium.....so far a visit to Gamma and Hornbach(major home stores) have not revealed any sika flex.....is there a specific part number or primary application or something else I should be looking for? Lots of silicone and latex sealers though. Patrick |
Sikaflex 291i Marine Adhesive & Sealant 300ml
white i used this my one |
Ive used black 221 and 291 (not sure what the difference is).
Here's a link for black 221 on the UK EBay site... http://www.ebay.co.uk/itm/Sikaflex-221-SIK...Swo0JWOhcQ Cheers Simon |
