Home > Td5 > Sealing panels
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Sealing panels
Had some wet carpeting in the load area left hand side next to the rear swing door next to wheel arch.
Previous owner or somebody backed into the rear and pushed the licence plate light assembly into the body panel about 5-10mm.
Anyway...it pushed it just enough to open a seam between the panel and the stiffener corner piece that the tail and signal lamps attach to. Noticed the gap using a flashlight from the inside in a dark garage.
I'm thinking of pulling the metal out a bit and sealing the seam with silicon from the inside. I thought I read on some other site that silicone is acidic and will attack the aluminum. Is this true? BTW....WTF is this sikaflex that everyone keeps talking about?
Patrick
Post #481569 12th Dec 2015 5:20pm
roel
I use silicon a lot and did not see any bad effects. Roel
2003 90 Td5 (2009-now)
Post #481673 13th Dec 2015 7:49am
Justtellme
Thanks Roel!
BTW.....are there and Land Rover breakers in southern Netherlands?
Patrick
Post #481682 13th Dec 2015 8:53am
dorsetsmith
sikaflex can be panted over . but silicone can not
sika also make different types seal and bonding for car, boats, planes
Post #481684 13th Dec 2015 8:57am
Justtellme
Understood and makes sense..I found sikaflex on a number of websites for construction sealing. Around windows brick, siding and flashing and says it can be painted over. Is this something people use to seal gaps in the defender floor panels...etc?
I think for my application, I can go wth silicone from the inside for now and keep looking for sikaflex.
Thanks to all
Patrick
Post #481688 13th Dec 2015 9:27am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I use Sikaflex on my Land Rover. I use it for sealing gaps, for wet fixing nuts/bots and any other sealing / adhesive needs.
Having seen silicon peel away when subject to harsh & wet conditions I wouldn't bother. Get Sikaflex and the job is done for good... Thumbs Up
Simon
Post #481690 13th Dec 2015 9:51am
mikeh501
Tigerseal is also good. Wouldn't bother with silicone.
Post #481695 13th Dec 2015 10:20am
Romadog
Do it once and do it right.....Sikaflex it ! Thumbs Up
Post #481705 13th Dec 2015 10:49am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
If you choose silicon sealant use NEUTRAL one, not an acidic type. But sikaflex is probably a better solution, it is not silicon based. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #481708 13th Dec 2015 11:03am
Swac3
Which one do you guys use?
Everyone just says "Use Sikaflex" which one? 3 Landrovers
Post #481720 13th Dec 2015 11:53am
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
+1 Sikaflex Thumbs Up
Post #481750 13th Dec 2015 1:04pm
Silver Back
I hadn't realised there were different types other than colour variations.
I've used this in the past and have been happy with the results. I was sealing the bulkhead / windscreen frame hence going for the black option.
http://www.screwfix.com/p/sika-sikaflex-eb...00ml/79299
Post #481752 13th Dec 2015 1:07pm
Justtellme
Ok....I'm living very close to the border of Germany, Netherlands and Belgium.....so far a visit to Gamma and Hornbach(major home stores) have not revealed any sika flex.....is there a specific part number or primary application or something else I should be looking for? Lots of silicone and latex sealers though.
Patrick
Post #481892 13th Dec 2015 9:43pm
dorsetsmith
Sikaflex 291i Marine Adhesive & Sealant 300ml
white
i used this my one
Post #481899 13th Dec 2015 9:57pm
couplands
Ive used black 221 and 291 (not sure what the difference is).
Here's a link for black 221 on the UK EBay site...
http://www.ebay.co.uk/itm/Sikaflex-221-SIK...Swo0JWOhcQ
Simon
Post #481926 13th Dec 2015 11:22pm
