Home > In Car Electronics > MultiMeter - What's Yours?
Page 3 of 4 <1234>
noworries4x4
Most used in my box is my very old Martingdale phase rotation tester still shows in Red Yellow Blue Black (You really don't want crane motors running backwards)
I really really need to get a Fluke rcd tester (test time and ma) and insulation tester. Huge money though unless anyone has a second hand one on here ????? If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #383014 29th Dec 2014 2:40pm
Cupboard
df1 wrote:
I'm looking into some kind of auto osciloscope next, if anyone has any suggestions.
Not sure if I need to get as fancy as the top end pico gear.
Anyone use the handheld fluke ones ?
If you want a cheap'n'cheerful scope you can do a lot worse than a DSO Nano. They're cheap and work well but are limited by only have one channel and a relatively low refresh rate of 1MHz.
The DSO Quad does improve things but I haven't personally used one.
Post #383051 29th Dec 2014 5:09pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
AVOs, now that takes me back....
So, without the aid of Google your starter for 10 is why "AVO"?
Post #388067 13th Jan 2015 6:03pm
Venomator
Amps, Volts, Ohms... Question
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #388163 13th Jan 2015 9:17pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
My toy of choice... Fluke 123 Scopemeter, dual channel 20MHz 'scope and multimeter..
Along with a Fluke 10 basic meter.. And somewhere in the shed is an old Fluke 77.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #388180 13th Jan 2015 9:50pm
scotty38
Re: ^ ^ ^
lol correct. Years ago I worked for an electronics company and there was loads of folk that didn't realise that Smile
Post #388242 13th Jan 2015 11:41pm
Continuing the "what do the initials stand for" quiz theme, who knows the full name of a BNC connector?
It never ceases to amaze me how many professionals who work daily with these have no idea or a completely wrong idea what the initials stand for!
Post #388252 13th Jan 2015 11:52pm
scotty38
Bayonet Neill Concelman
Post #388257 14th Jan 2015 12:06am
Thumbs Up
Scotty38 wins the virtual coconut, well done!
Post #388260 14th Jan 2015 12:15am
Supacat wrote:
Still use an old Avo handed down from my father
Just a quick question for anyone that might know the answer.
Got the AVO out yesterday to check a torch and couldn't get a full needle deflection when touching the probes together to check for continuity. The unit has a AA battery with one corroded terminal. Is this in the continuity circuit or should I be looking elsewhere for the issue?
Post #481475 12th Dec 2015 10:24am
K9F
Many of the older Avos have a 'null' facility to zero the pointer when the probes are together. Did you try turning the screw below the dial to null it? If it still will not null you need a new battery. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #481595 12th Dec 2015 7:19pm
Thanks - I'll try a new battery and some emery paper on the contacts Thumbs Up
Adjusted the null dial to no effect.
Post #481741 13th Dec 2015 12:36pm
dorsetsmith
Flukes AND Avo 8,meters. Thumbs Up
Post #481775 13th Dec 2015 2:38pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
I have the old and new models of the Fluke 77, a 21 and a 117 Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #481814 13th Dec 2015 5:48pm
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
I bought this one recently, it has every feature one could think of in a Multimeter.. no complains so far.. and it's a bargain for the features it offers..
http://www.amazon.com/Mastech-MS8268-MS826...B000JQ4O2U
Post #483885 20th Dec 2015 10:50am
Page 3 of 4 <1234>
