![]() | Home > In Car Electronics > MultiMeter - What's Yours? |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
Most used in my box is my very old Martingdale phase rotation tester still shows in Red Yellow Blue Black (You really don't want crane motors running backwards)
I really really need to get a Fluke rcd tester (test time and ma) and insulation tester. Huge money though unless anyone has a second hand one on here ????? If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
If you want a cheap'n'cheerful scope you can do a lot worse than a DSO Nano. They're cheap and work well but are limited by only have one channel and a relatively low refresh rate of 1MHz. The DSO Quad does improve things but I haven't personally used one. |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
AVOs, now that takes me back....
So, without the aid of Google your starter for 10 is why "AVO"? |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Amps, Volts, Ohms...
![]() Rog... ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
lol correct. Years ago I worked for an electronics company and there was loads of folk that didn't realise that ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17871 ![]() ![]() ![]() |
Continuing the "what do the initials stand for" quiz theme, who knows the full name of a BNC connector?
It never ceases to amaze me how many professionals who work daily with these have no idea or a completely wrong idea what the initials stand for! |
Bayonet Neill Concelman
![]() Scotty38 wins the virtual coconut, well done! |
Just a quick question for anyone that might know the answer. Got the AVO out yesterday to check a torch and couldn't get a full needle deflection when touching the probes together to check for continuity. The unit has a AA battery with one corroded terminal. Is this in the continuity circuit or should I be looking elsewhere for the issue? |
Many of the older Avos have a 'null' facility to zero the pointer when the probes are together. Did you try turning the screw below the dial to null it? If it still will not null you need a new battery. If you go through life with your head in the sand....all people will see is an ar5e!!
Thanks - I'll try a new battery and some emery paper on the contacts
![]() Adjusted the null dial to no effect. |
Flukes AND Avo 8,meters.
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
I have the old and new models of the Fluke 77, a 21 and a 117 Cheers Simon
I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle Last edited by Ryderoo on 20th Dec 2015 11:28am. Edited 1 time in total |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 ![]() ![]() ![]() |
I bought this one recently, it has every feature one could think of in a Multimeter.. no complains so far.. and it's a bargain for the features it offers..
![]() http://www.amazon.com/Mastech-MS8268-MS826...B000JQ4O2U |
