![]() | Home > Td5 > Problem with interior light |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2034 ![]() ![]() |
Do they flash every time or just the once?
Easy checks are to pop off the lense, check the bulb condition, electrical contacts, check the plugs are in tight and it's not a loose connection. Can you manually switch them on as normal and they work ok? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
Problem solved with nanocom
In the 10AS menu interior lights needs to be set to SMART Now it works Thanks RRUK for hints. 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
