Home > Td5 > Problem with interior light
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
something went wrong with my 2003 110SW interior light.
After disarming the alarm interior lamps just flash once and go off.
When opening the door, lights do not go on.
Any advice where the devil sits? 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #480102 7th Dec 2015 10:18pm
RRUK
Do they flash every time or just the once?
Easy checks are to pop off the lense, check the bulb condition, electrical contacts, check the plugs are in tight and it's not a loose connection.
Can you manually switch them on as normal and they work ok? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #480139 8th Dec 2015 12:45am
TomekW
Problem solved with nanocom
In the 10AS menu interior lights needs to be set to SMART
Now it works
Thanks RRUK for hints. 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
Post #480210 8th Dec 2015 11:21am
