![]() | Home > Technical > diff lock , sorry , i have searched |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
No spring across the gate. Check that there is moth pushing it back over, like thectrim, carpet etc
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6027 ![]() ![]() ![]() |
It could just be it needs adjusting. Mine would do the same, in the end removed the transmission tunnel cover, and adjusted/tested/lubed all linkages and now good. 1999 Defender TD5 110
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Just been out removed all that middle bit , put a 13mm socket on the spiggatt n bobs ya uncle , it's now working , the slop in the mech just did not have enough push , the lever now works a treat , will grease it up n replace any bad bits
![]() ![]() Click image to enlarge |
![]() Mine needed adjusting on the middle pivot point 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
that looks to be were my problem lies , the arm appears to twist on the slop , so next weekend , in day light , i`ll go through it all
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
On mine, the little short wire linkage at the bottom of the arm was seized solid in the holes. When you pushed the lever it would just spring back. A lot of waggling the link and plenty of copper grease fixed it.
Cheers Simon |
I found this link helpful when doing mine
http://www.ashcroft-transmissions.co.uk/fr...faq-s.html 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
