Home > Technical > diff lock , sorry , i have searched
razz
2001 Defender 90 Td5 PU Caledonian Blue
sorry to ask a diff lock question , but its new to me . i have over several weeks , sprayed lots of wd40 onto the mechanism , yet the lever is very springy when trying to get diff lock , high n low are easy . when i push the lever across to diff lock , the light comes on but the lever just springs back as soon as i remove my hand , i can see the spiggart thats sticks out of the box and that is turning with the lever , i have tried driving slowly in both high/ low in first yet i still can not get it to engage , is there a real art to engage the diff lock , and does the fact that the lever will spring back when trying to engage df that it could be seized in the box , its got new oil , apologies again , but if it there , i might as well have it ready , just incase , thanks ady
Post #479729 6th Dec 2015 7:24pm
T1G UP
No spring across the gate. Check that there is moth pushing it back over, like thectrim, carpet etc
Post #479741 6th Dec 2015 7:51pm
excossack
It could just be it needs adjusting. Mine would do the same, in the end removed the transmission tunnel cover, and adjusted/tested/lubed all linkages and now good. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #479754 6th Dec 2015 8:07pm
razz
Just been out removed all that middle bit , put a 13mm socket on the spiggatt n bobs ya uncle , it's now working , the slop in the mech just did not have enough push , the lever now works a treat , will grease it up n replace any bad bits Smile yeee harrrr
Post #479757 6th Dec 2015 8:25pm
excossack
Smile
Mine needed adjusting on the middle pivot point 1999 Defender TD5 110
Regards
John M0VAZ
Post #479761 6th Dec 2015 8:31pm
razz
that looks to be were my problem lies , the arm appears to twist on the slop , so next weekend , in day light , i`ll go through it all Smile thanks everyone Thumbs Up
Post #479774 6th Dec 2015 8:54pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
On mine, the little short wire linkage at the bottom of the arm was seized solid in the holes. When you pushed the lever it would just spring back. A lot of waggling the link and plenty of copper grease fixed it.
Simon
Post #479787 6th Dec 2015 9:25pm
excossack
I found this link helpful when doing mine
http://www.ashcroft-transmissions.co.uk/fr...faq-s.html 1999 Defender TD5 110
Regards
John M0VAZ
Post #479794 6th Dec 2015 9:43pm
