Home > Puma (Tdci) > Radiator Muffs
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Radiator Muffs
Morning All,
Can anyone tell me the pro's and con's of fitting a radiator muff like the exmoor one
http://www.exmoortrim.co.uk/index.php/cata...k-pvc.html
(Hope that link works Confused )
Rosco 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #47675 7th Dec 2010 10:12am
RED-DOT
Not a good idea on intercooled Defenders as the intercooler needs cold air flow.. expect black smoke and raised MPG.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #47704 7th Dec 2010 2:02pm
Rosco
Thanks for that Red-dot
I'll put that idea to bed then
Cheers 2007 - Stornoway Grey 90 XS SW - Gone
Post #47717 7th Dec 2010 3:24pm
BigMike
before you do that rosco, if you do a lot of offroad driving without high load (ie low speed, steep hills etc) in winter, a rad muff will help with overcoming the problem of a low engine temp and a low heater temp. as long as you keep the flap open a little it ll be fine. To put that into context, At the weekend i spent a lot of time idling in very cold conditions and the gauge went down so low that the heater just really wasn't doing much. A rad muff would have really helped that. Also helpful on very cold mornings, you keep the flap closed but then have to hop out and open it when the engine gets to temperature.
also v v useful if you do any wading. a few weeks ago in wales i went thorugh deep water which was full of grass and all kinds of crap. took me the best part of half a day to clear it all out of the radiator, and at the time I wished I had a rad muff to close.
Post #47725 7th Dec 2010 4:14pm
Toplink
In very cold weather (like now) I use an empty feed sack as a rad muff.Works fine on short journeys and helps with quick warm up .Keeps temp up when working at low revs off road.I have noticed no change in fuel consumption or any black smoke and no loss of power. Best of all its cheap. :D
Post #47773 7th Dec 2010 10:39pm
Rosco
BigMike/Toplink cheers for the additional advice.
Maybe I'll put it back on the Christmas list. The rad muff that is. Im fairly certain my better half wont give me an empty feed sack as a gift.
Post #47801 8th Dec 2010 9:49am
DAZ110
A muff would be nicer Wink
Post #47803 8th Dec 2010 9:59am
