Home > Maintenance & Modifications > DRL Controller
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
DRL Controller
Hey, it looks like my DRL controller has gone on the fritz!!! They stay on even when the engine is off now!
Can anybody recommend a controller? There a thousands on eBay but you never know what you're getting!
I had a dectane one but I can't find it cheaper than £20+ which seems a little steep!
Cheers 2006 Defender Double Cab- Zambezi Silver
Post #477916 1st Dec 2015 10:55am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Maybe approach the likes of urban truck and outbound 4x4. They could possibly supply you with one. 2002 110 td5
Post #477922 1st Dec 2015 11:05am
Lost for Words
Arrow http://www.halfords.com/workshop-tools/gar...0amp-4-pin Whistle
Edit: ...and: http://www.halfords.com/workshop-tools/gar...-30a-5-pin Wink Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #477923 1st Dec 2015 11:11am
airpusher
Jimb1978, I hate to think of the cost from urban truck once they put there premium on it! Ouch!!
LFW, I can't see how they can be used to control DRL to turn them off when my main lights come on. I'm
Not much for electrical a bar the basics.
Post #477935 1st Dec 2015 11:45am
Martin
Site Admin
How do you want them to work?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #477938 1st Dec 2015 11:51am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Duckworth Parts? My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #477949 1st Dec 2015 12:13pm
airpusher
Martin, Just a basic control really. DRL on when I start the car, DRL off when I turn on my lights. Not really bothered about dimming etc.
That's what the last box did before its broke.
Good call, I'll drop Dan a message and what they have.
Post #477951 1st Dec 2015 12:23pm
Lost for Words
Drawn you a little diagram:
The first relay turns them on with an ignition live, the second shuts them off with the lights. Thumbs Up Visiting from DISCO3.CO.UK
Post #477953 1st Dec 2015 12:34pm
Martin
Site Admin
Drat - too slow Twisted Evil
I've assumed you can power the DRLs straight from an ignition feed, but otherwise as LfW has shown - his left hand relay creates a dedicated ignition switched power feed Thumbs Up
You need a changeover type relay, one with 87 and 87a terminals
Relay terminal 30: +12V Ignition
Relay terminal 87a: to DRLs
Relay terminal 85: Side light
Relay terminal 86: Ground
Basically it is set up as a normally closed switch connecting ignition to the DRLs which is opened by the side lights turning on.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #477956 1st Dec 2015 12:57pm
Martin
Site Admin
My only comment about using Dip Beam as the shut-off signal is that the DRLs will come back on with main beam.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #477958 1st Dec 2015 1:01pm
Lost for Words
Good point, Martin. Thumbs Up
Personally, I also prefer it if people use the sidelights to shut them off (well...I'm not a fan of DRLs anyway). Visiting from DISCO3.CO.UK
Post #477964 1st Dec 2015 1:14pm
airpusher
Sorry for the slow response guys I'm out with my son and the signals bad.
LFW & Martin, that's brill, thank you.
Would this comply with the DRL regs as mine are in the bumper and previously went off and stayed off side lights or dipped beam.
Martin, by main beam do you mean full beam? If so I'd be happy with that but not sure about MOT man.
At present they are powered directly from the batter via aux fuse box and attach to side light.
Edit, just got it! Use side lights and they will stay off regardless, use dip and they'll come back on with main! Sorry.
To be honest I put them on to try them out and I'm not that keen but they are there so I feel they should work. 2006 Defender Double Cab- Zambezi Silver
Post #477965 1st Dec 2015 1:18pm
JOW240725
I was looking for a controller that would dim the DRL's rather than turn off with main lights and was recommended this by a site sponsor:-
http://britelightleds.co.uk/drl-day-time-r...ng-harness
Post #477967 1st Dec 2015 1:30pm
Lost for Words
Yes, it would be the full beam. Not such an issue in itself but it would drastically increase wear on the relay. I would simply use your existing connections. IIRC, there's no legal requirement to shut non-obligatory DRLs off with the lights anyway. Thumbs Up Visiting from DISCO3.CO.UK
Post #477968 1st Dec 2015 1:30pm
airpusher
Thanks guys,
All food for though, I'll get my head toothed this week and get them sorted.
I'll probably put it up for sale as soon as I fix it as I'll not like it!!! Lol
Again, thanks
JOW.... Thanks, I'll have a look at that too once I get better signal. 2006 Defender Double Cab- Zambezi Silver
Post #477969 1st Dec 2015 1:33pm
