![]() | Home > Maintenance & Modifications > DRL Controller |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Not really sure you need the first relay for ignition to be honest. The DRLs shouldn't pull much current so a feed could be taken from an existing ignition feed then the relay just used to switch them off with the headlights/sidelights.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 200 |
No, probably not - I'm just not making any assumptions as to the type of DRLs and ignition feed.
Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
| airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372
OK, stupid question alert!!!!
Where is the best place to get the 12v Ignition feed in either drivers or passages seat box? Edit: I have a factory/dealer fitted front spots relay fitted but not used at present (Soon to be rectified when I find a nice way to mount them) would that have a 12v Ignition leading to it? 2006 Defender Double Cab- Zambezi Silver |
