Home > Maintenance & Modifications > Webasto or Eberspacher coolant heater advice please |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 |
I went through this same exercise a few years ago on a 2003 TD5 ( sold now ) and in the end I went for an Eberspacher for no other reason than they had the closest installer to me. I personally couldn't differentiate between the 2 brands.
Having said that I can't fault the Eberspacher it was a great bit of kit and never caused me any problems. |
25th Nov 2015 3:20pm |
knrv8 Member Since: 30 Mar 2010 Location: Eastleigh Posts: 7 |
I live near Winchester. Could you say who you used if you were happy with the work.
Thank you. |
26th Nov 2015 1:01pm |
Hi
At the time I wasn't working in Winchester so I used a Swindon based company near work. Halls Electrical Ltd Unit 1, Clearwater Business Park, Frankland Road, Blagrove, Swindon, Wiltshire, SN5 8YZ Not too far from Eastleigh mind but they did need the vehicle for 2 days, they do a lot of electrical work for the police and highway patrols so the standard is high. |
26th Nov 2015 2:52pm |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
any fitting places up here in scotland i would love to get one for da winter time
26th Nov 2015 5:09pm |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 |
I've got an Webasto Thermo Top C fitted to my 110 and I love it. One of the best mods I've made!! Cant beat jumping into a nice toasty car in the morning. Saves engine wear too. I opted for the long range remote, the timer unit and Ive also got an override Carling switch. The override is because you can only run it for an hour on the timer unit. Want to do an overland through the Nordic countries in winter and fancy leaving it running to give the engine a chance of staying warm when its not under load.
Cetane |
26th Nov 2015 6:52pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7688 |
i have a termo Top C in my tdci, and had the same in my td5 previously, have always used Webasto, seems to be more knowledge on them out there and more bits in breakers should the need arise. having said that both mine were new. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
26th Nov 2015 10:47pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I Have just fitted a Webasto thermotop into mine.
Took a bit of brain scratching and a little bit of trial and error but it now seems to be working fine Thread here in case you want a idea of whats involved http://www.defender2.net/forum/topic32902.html Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
27th Nov 2015 1:38pm |
Crs90 Member Since: 08 Jul 2015 Location: In my excavator Posts: 82 |
Thanks
27th Nov 2015 8:52pm |
not tricky to fit, couple of +ve feeds, one -ve feed and some basic plumbing .. if that is a challenge, talk to Derrick at LRS he's happy to fit
28th Nov 2015 12:35am |
