![]() | Home > Technical > Towbar extender for bike rack |
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 ![]() ![]() ![]() |
Need some advice on this
Have a Naka wheel carrier and 16" wheels on Sawtooth Trying to fit the Thule bike rack but it won't clear the wheel If I get a Disco 2 longer tow bar will it clear the wheel? Have read the thread but just need a definite before I buy one |
Nobody responded on the Disco 2 bar, so thought sod it, and bought one
If anybody is reading this post and does know, please tell me? If I fit the new Disco 2 bar, would I still need the 4x4 adaptor? Will post the results regardless next week when everything turns up |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
I didn't respond as I don't know for your specific tyre. For a boost alloy with General Grabber AT will be fine. No other connectors needed. I have a Nak wheel carrier also ( non-stainless).
Thanks Kmac
Fitted the Thule and with the Disco 2 tow bar, I can get away without the adaptor However have left the old Pendle block in place and added a spacer Post picture later Simon |
Blakey007 Member Since: 13 Aug 2017 Location: Winchester Posts: 37 ![]() ![]() ![]() |
Where did you buy the Disco 2 extended tow ball from?
looking to purchase one so I can use my bike rack without removing spare wheel |
Hi Blake
Got mine off eBay - Ł65 I think but don't quote me Still doesn't clear my tyre but I have a Naka wheel carrier and Saw tooths Does work if I put the Thule adaptor on afterwards, but I think I am going for a Fiamma bike rack Simon |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
This is an old thread with lots of suggestions that go back a few years but I thought I would add an input for those with a Dixon Bate tow bracket fitted. I designed mine along the same lines as the Dixon Bate but also use a second set of holes further up to reduce the cantilever loads. It gives me two height positions but with a bike carrier it doesn't really matter what height it is. I found I needed to use the Al-Ko extended tow ball rather then the standard for my Thule Euro 3 bike rack. The attached pictures are with the standard ball so with the Al Ko it will move the ball further back.I post some pictures with the correct tow ball and the rack fitted. It's certainly strong and really easy to refit the original Dixon Bate tow ball plate. I had to make another clevis pin for the upper support as the 3/4" pin with the Dixon Bate is extra long and seems non standard when I looked in my local farm machinery suppliers.
![]() Click image to enlarge ![]() Click image to enlarge "You are never to old to learn something new" |
That looks cool - well done
Thanks kmac. The Al-Ko ball turns up today and I've primed and sprayed the extender in black to match the back area. I also decided to make two new clevis pins from A4 Stainless steel because pulling them in and out wears off the paint or nickel plating and they end up going rusty making it hard to pull them out next time. I'll post some more pics when it's all done with the bike rack fitted. My wife has a heavy electric bike so I wanted to make it really strong which it has turned out to be. Note: for anyone who makes a similar design the welds between the diagonal and the horizontal need to be full butt. I prepped and TIG welded mine initially in situ on the Dixon Bate to get it aligned then took it off to finish the welds on the bench. It's important to weld in the correct sequence and directions so you don't put in twist distortion. This bit takes a bit of thinking about. "You are never to old to learn something new"
Below some pictures with the Al-ko ball fitted and with two bikes on the rack
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge "You are never to old to learn something new" |
Here is some pictures of the finished article painted black with Al-Ko extended 50 mm ball and marine grade stainless Clevis pins and R clips.
salar76 Member Since: 26 Jan 2018 Location: Scotland Posts: 5 ![]() ![]() ![]() |
Thanks to some of the ideas on this thread, I managed to crack the challenge I was having to get bikes onto the back of my 110. I went down the Disco 2 towball route - a lot cheaper than the other option I was considering in getting a NAS step and building out with a spacer. The biggest challenge was getting the towball off the seized up Disco 2 tow bar it came with...after a couple of hours and a now knackered Halfords Advanced socket wrench we got there...
First I tried without adding a spacer, it just about worked but was a bit tight - the carrier clicked into place but was hard to get space to take off as the handle caught on the spare tyre. Put in a 2” spacer and it’s ideal...a smaller spacer would be fine too. With the 2” spacer the door opens fully too. Just need some Hammerite on the towball and it’ll be job done. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
1113562 Member Since: 17 Nov 2013 Location: Abergavenny, Wales Posts: 6 ![]() ![]() ![]() |
Probably fine for a small bike rack but I'm not sure I would like to tow a caravan or horse box on such a set-up. I don't like using spacers and long bolts. Too much cantilever force especially with such a long neck tow ball that amplifies the cantilever forces. I tend to switch between my bike rack, various trailers and a caravan so I designed a tow bracket that is suitable for all uses. The Defender is rated to tow up to 3.5 Tonnes so the towing bracket really should be capable of meeting the resulting dynamic loads with an adequate factor of safety. Shoot me if I'm slowing you down!
Where did you purchase the spacer from salar76?
Agree with 1113562 that it maybe not a good idea to use if towing a trailer or Horse box etc but if used only for a bike rack I think its ideal. |
