![]() | Home > Technical > TD5 Low beam not working |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Sounds like another possible stalk switch problem to me? Here are a few TD5 related threads on the subject matter.
http://www.defender2.net/forum/topic17125....alk+switch http://www.defender2.net/forum/topic38911....alk+switch http://www.defender2.net/forum/topic33261....alk+switch If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 18th Nov 2015 1:12pm. Edited 1 time in total |
| tasr12 Member Since: 09 Jun 2013 Location: Dorset Posts: 228
I had exactly this last week on my 02 TD5. In the end it required the dash off and the wiring behind the fuse box sorting (there was a break in there somewhere). I had tried: bulbs, fuses, relays and switches (supposedly the most commmon failure) before handing it to AL Services to resolve....which they did in about 2.5hrs! 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
The most common fault with Defender headlights is that one or other of the two switches has melted. I have had both over the years.
If you have sidelights Ok, but no headlights at all except on flash, it is the main light switch on the column, and this is the most common failure. Usually the sidelights will also go out when the headlight switch is in the ON position in this case. If you have sidelights whcih work normally but have either lost just the dip beam but have main beam (most common), or have lost main beam but have dip beam (less common), then usually it is the dip/main switch on the column. There are of course other components which can cause similar failures, but usually it is one or other switch. In your case, I would test the dip/main switch with a meter before going further, it is highly likely that this is the faulty part. |
| BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 736
Thanks for the replies guys, I've had a look at the indicator/ main beam stalk an it appears to be fine, no melting and every thing making contact where it should. One thing I have found out now is that there is no power to the low beam fuses when the ignition is on, where to look now?
Cheers |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
The dipped beam fuses are "live" only when the switch is in the dipped beam position.
I assume the main beam works totally normally, when latched in the pushed away position, rather than just when held in the flash position? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Hmm wonder if it is a dim dip relay failure?
On a Td5 the dip beam supply from the switch to the fuses is "broken" by the dim dip relay. Although the two relay positions are to connect the dipped beam fuses to either the dip switch or permanent supply via the dim dip resistor, if the relay is jammed between the two or otherwise failed, there will be a connection to neither. The quick test would be to remove the dim dip relay (under the wing near the brake booster) and bridge positions 2 and 8, which should reconnect the dipped beam fuses to the switch directly. Martin 1988 90 Td5 NAS soft top
2015 D90 XS SW |
^^^ winner!!! Dim-dip relay had had it! The pink one behind the dash. Have done the bypass and all lights work as they should! Thanks Martin
Sorry yes it is behind the dash on the Td5
2015 D90 XS SW |
On the Puma the dim dip arrangement (where fitted - ie to models which are "commercial" in origin) is much simpler, and it is much easier to disable permanently this ultra-useless, bulb-eating feature!
Glad you're sorted, anyway (next time it will be a melted switch)! |
Not so, the Puma system is the same as the Td5
2015 D90 XS SW |
Glad it was a simple fix for you - I wish mine had been!
Tom. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
Thanks Martin, you are of course absolutely right!
For some reason I have always been under the impression that the Puma doesn't have the pink relay, but your comment inspired me to look at the wiring diagram and I see that it actually does. Everyday a schoolday! |
2015 D90 XS SW |
Thanks for all the help guys!
