Home > Technical > TD5 Low beam not working
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Hi all, minor crisis last night in that we lost the low beam on my dads td5, Thank fully he wasn't too far from home. Ive had a bit of a look round this morning and am a bit stumped, its got a lot more elecrtickery than my 300. Its a base spec 02 td5 with trucklite led headlights. All lights work except low beam, so side lights work, flick the switch to low beam and nothing happens, flick the high beam on and all work fine Confused
First port of call was the light switch, of which seems to be fine inside and using a multimeter, seems to do its job. fuses all fine for the low beam too. Next I removed the lights to see if they were the issue and they work fine, but not getting power to the low beam pin in the connector on the vehicle, so now thinking its somewhere between the headlight connector and the switch. Is there any relays in the low beam circuit that might be causing this problem?
There seems to be plenty of results on Google for vehicles that have lost all lights or all headlight function, but couldn't find anything that matches these symptoms.
Post #473856 18th Nov 2015 12:49pm
K9F
Sounds like another possible stalk switch problem to me? Here are a few TD5 related threads on the subject matter.
http://www.defender2.net/forum/topic17125....alk+switch
http://www.defender2.net/forum/topic38911....alk+switch
http://www.defender2.net/forum/topic33261....alk+switch If you go through life with your head in the sand....all people will see is an ar5e!!
Post #473866 18th Nov 2015 1:10pm
tasr12
England 2002 Defender 110 Td5 CSW Zambezi Silver
I had exactly this last week on my 02 TD5. In the end it required the dash off and the wiring behind the fuse box sorting (there was a break in there somewhere). I had tried: bulbs, fuses, relays and switches (supposedly the most commmon failure) before handing it to AL Services to resolve....which they did in about 2.5hrs! 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD
Post #473867 18th Nov 2015 1:11pm
The most common fault with Defender headlights is that one or other of the two switches has melted. I have had both over the years.
If you have sidelights Ok, but no headlights at all except on flash, it is the main light switch on the column, and this is the most common failure. Usually the sidelights will also go out when the headlight switch is in the ON position in this case.
If you have sidelights whcih work normally but have either lost just the dip beam but have main beam (most common), or have lost main beam but have dip beam (less common), then usually it is the dip/main switch on the column.
There are of course other components which can cause similar failures, but usually it is one or other switch.
In your case, I would test the dip/main switch with a meter before going further, it is highly likely that this is the faulty part.
Post #473887 18th Nov 2015 2:13pm
BuckBlu110
Thanks for the replies guys, I've had a look at the indicator/ main beam stalk an it appears to be fine, no melting and every thing making contact where it should. One thing I have found out now is that there is no power to the low beam fuses when the ignition is on, where to look now?
Post #473898 18th Nov 2015 3:15pm
Martin
Site Admin
The dipped beam fuses are "live" only when the switch is in the dipped beam position.
I assume the main beam works totally normally, when latched in the pushed away position, rather than just when held in the flash position?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473900 18th Nov 2015 3:44pm
Martin
Site Admin
Hmm wonder if it is a dim dip relay failure?
On a Td5 the dip beam supply from the switch to the fuses is "broken" by the dim dip relay.
Although the two relay positions are to connect the dipped beam fuses to either the dip switch or permanent supply via the dim dip resistor, if the relay is jammed between the two or otherwise failed, there will be a connection to neither.
The quick test would be to remove the dim dip relay (under the wing near the brake booster) and bridge positions 2 and 8, which should reconnect the dipped beam fuses to the switch directly.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473903 18th Nov 2015 3:54pm
BuckBlu110
^^^ winner!!! Dim-dip relay had had it! The pink one behind the dash. Have done the bypass and all lights work as they should! Thanks Martin Very Happy
Post #473906 18th Nov 2015 4:14pm
Martin
Site Admin
Sorry yes it is behind the dash on the Td5 Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473907 18th Nov 2015 4:15pm
On the Puma the dim dip arrangement (where fitted - ie to models which are "commercial" in origin) is much simpler, and it is much easier to disable permanently this ultra-useless, bulb-eating feature!
Glad you're sorted, anyway (next time it will be a melted switch)!
Post #473937 18th Nov 2015 6:25pm
Martin
Site Admin
Not so, the Puma system is the same as the Td5 Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473939 18th Nov 2015 6:26pm
tasr12
Glad it was a simple fix for you - I wish mine had been!
Tom. 2002 110 CSW TD5, Zambezi Silver
Post #473943 18th Nov 2015 6:33pm
Thanks Martin, you are of course absolutely right!
For some reason I have always been under the impression that the Puma doesn't have the pink relay, but your comment inspired me to look at the wiring diagram and I see that it actually does.
Everyday a schoolday! Thumbs Up
Post #473946 18th Nov 2015 6:38pm
Martin
Site Admin
Ner Ner  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473947 18th Nov 2015 6:38pm
BuckBlu110
Thanks for all the help guys! Thumbs Up
Post #473976 18th Nov 2015 7:50pm
