![]() | Home > Puma (Tdci) > Any tips / tricks / advice on 1st time brake job. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
You don't need to remove them. Bit I would do away with the spacer and stake nut and revert been to the two nuts and licking tab. Cheers
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Make sure you have all the bits and torque settings before you start including fluids and bleed kit, also ensure you have new calliper bolts as they are a one time use on the WOLF fleet I assume they will be on others due to the loctite on them. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Top tip for stake nuts....
Get genuine ones, I had one genuine one, and one Britpart. The Britpart one picked the threads up on the stub axle halfway on! I ended up having to drill it off the stub, then re dressing with a thread file. NEVER AGAIN..... Wanted, Forward Control Anything considered. |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964
If you're not used to bearings and that let a grown up do it were talking brakes here
| expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58
Thanks everyone, keep'em coming. Sorry if I come off as dumb, because I really am, this is my first LR.
I have a Workshop manual and the torques settings so that should be good. As for Stake Nuts, I assume you are referring to the axle nuts. I got replacements from Paddock's. should be good. I have new caliper bolts coming to. What happens when I go to remove the current ones that prevents me from cleaning them up and re-applying anti-seize to the bolts and use them again? I will leave the bearing alone, thanks. JST: you say "do away with the spacer and stake nut and revert been to the two nuts and licking tab." What do you mean by two nuts and a licking tab? thanks, Rob |
Quote..
As for Stake Nuts, I assume you are referring to the axle nuts. I got replacements from Paddock's. should be good. As long as they are in a sealed bag with Land Rover genuine parts written on them..... Wanted, Forward Control Anything considered. |
The calliper bolts are coated with a thread locking compound to prevent them from working loose, not a anti-seize compound NEVER use that on the calliper bolts. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
| Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 409
A tip I picked up a few weeks ago was: once you've got your hubs off and want to unbolt the disk bolts, lay your wheel on the ground so the inner face is upwards, place the hub's wheel studs into the wheel holes and this gives you an easy way of holding it while you undo the disk retaining bolts.
Saves wrestling with the hub on the bench or in the vice. |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
There's no reference to coating these bolts with anything in the current workshop manual. |
They are pre coated from factory. 80" 80" 86" 88" 90"
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Buy a quality 12 point socket for the caliper bolts (13mm,I think),some of them can be tough as hell!Always worth cleaning and greasing bearings especially if they're out,manufacturers are tight
What size socket do you use to remove the Stake nut (Axle Nut)?
52mm 80" 80" 86" 88" 90"
