Home > Puma (Tdci) > Any tips / tricks / advice on 1st time brake job.
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
I am about to do a first time, new brake disc (Rotors) and new pads on all four wheels of my MY07 110. Does anyone have any tips /tricks / advice?
Do I need to remove the wheel bearing pack and clean and re-grease as I change out the disc or just leave it alone? (no known issues with the wheel bearings)
Post #472711 15th Nov 2015 4:45pm
jst
You don't need to remove them. Bit I would do away with the spacer and stake nut and revert been to the two nuts and licking tab. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #472735 15th Nov 2015 7:10pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Make sure you have all the bits and torque settings before you start including fluids and bleed kit, also ensure you have new calliper bolts as they are a one time use on the WOLF fleet I assume they will be on others due to the loctite on them. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #472737 15th Nov 2015 7:12pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Top tip for stake nuts....
Get genuine ones, I had one genuine one, and one Britpart.
The Britpart one picked the threads up on the stub axle halfway on!
I ended up having to drill it off the stub, then re dressing with a thread file.
NEVER AGAIN..... Evil or Very Mad 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #472744 15th Nov 2015 7:24pm
ibexman
If you're not used to bearings and that let a grown up do it were talking brakes here Whistle
Post #472752 15th Nov 2015 7:39pm
expatRob
Bearings Stake nuts and Bleed kit
Thanks everyone, keep'em coming. Sorry if I come off as dumb, because I really am, this is my first LR.
I have a Workshop manual and the torques settings so that should be good.
As for Stake Nuts, I assume you are referring to the axle nuts. I got replacements from Paddock's. should be good.
I have new caliper bolts coming to. What happens when I go to remove the current ones that prevents me from cleaning them up and re-applying anti-seize to the bolts and use them again?
I will leave the bearing alone, thanks.
JST: you say "do away with the spacer and stake nut and revert been to the two nuts and licking tab." What do you mean by two nuts and a licking tab?
thanks,
Rob
Post #472784 15th Nov 2015 8:20pm
ian series 1
Quote..
As long as they are in a sealed bag with Land Rover genuine parts written on them..... Whistle 80" 80" 86" 88" 90"
Post #472795 15th Nov 2015 8:33pm
Mash
The calliper bolts are coated with a thread locking compound to prevent them from working loose, not a anti-seize compound NEVER use that on the calliper bolts. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #472812 15th Nov 2015 9:09pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
A tip I picked up a few weeks ago was: once you've got your hubs off and want to unbolt the disk bolts, lay your wheel on the ground so the inner face is upwards, place the hub's wheel studs into the wheel holes and this gives you an easy way of holding it while you undo the disk retaining bolts.
Saves wrestling with the hub on the bench or in the vice. Thumbs Up
Post #472816 15th Nov 2015 9:17pm
There's no reference to coating these bolts with anything in the current workshop manual.
Post #472880 15th Nov 2015 10:57pm
ian series 1
They are pre coated from factory. 80" 80" 86" 88" 90"
Post #472882 15th Nov 2015 11:00pm
jimbob7
Buy a quality 12 point socket for the caliper bolts (13mm,I think),some of them can be tough as hell!Always worth cleaning and greasing bearings especially if they're out,manufacturers are tight Censored when it comes to greasing anything.I stuck with the original stake nut design (new stake nut tho) coz it's simple and it worked. Pov.spec,ftw. 2006, 110,TD5.
Post #472968 16th Nov 2015 9:16am
expatRob
Stake nut (Axle Nut) Socket size
What size socket do you use to remove the Stake nut (Axle Nut)?
Post #473263 16th Nov 2015 10:10pm
ian series 1
52mm 80" 80" 86" 88" 90"
Post #473273 16th Nov 2015 10:23pm
