![]() | Home > Technical > losing power after heavy fuel demand |
| Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310
Possible vcv? I beleive they are prone to failure and don't show any fault codes.
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2420
Have you tried running it without the fuel cap James ? Does sound like the fuel supply can't keep up with demand.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491
^^^ is my thoughts too. not looked yet though. Cheers
dropped the tank today, someone had fitted the rear cage bolts in such a way to limited fuel and air supplies
pipes changed. refitting the tank was fun James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Shane Member Since: 27 Jul 2016 Location: Doncaster Posts: 4
I have the same problem and wanted to know if you've resolved it yet.
regards Shane |
Hi Shane, yes it was a blocked breather for the fuel tank. Cheers
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
Fuel filter needing changing can degrade performance too.
As far as I'm aware, never changed it myself but they just need diesel priming then fitting. |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
I just fill the new filter with diesel, screw it on and turn on the engine. Never needed primed. 1982 88" 2.25 diesel
| jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231
As spud said, fill new filter with diesel and no need to prime system.
Running it at a fast idle for a couple of mins also helps pull it through. Jonesie enjoying the sun before it blows a hoolie tmrw Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
| All times are GMT |
