![]() | Home > Technical > losing power after heavy fuel demand |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Possible vcv? I beleive they are prone to failure and don't show any fault codes.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
Have you tried running it without the fuel cap James ? Does sound like the fuel supply can't keep up with demand.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8397 ![]() ![]() ![]() |
^^^ is my thoughts too. not looked yet though. Cheers
dropped the tank today, someone had fitted the rear cage bolts in such a way to limited fuel and air supplies
![]() pipes changed. refitting the tank was fun ![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Shane Member Since: 27 Jul 2016 Location: Doncaster Posts: 4 ![]() ![]() ![]() |
I have the same problem and wanted to know if you've resolved it yet.
regards Shane |
Hi Shane, yes it was a blocked breather for the fuel tank. Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Fuel filter needing changing can degrade performance too.
As far as I'm aware, never changed it myself but they just need diesel priming then fitting. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
I just fill the new filter with diesel, screw it on and turn on the engine. Never needed primed. 1982 88" 2.25 diesel
jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231 ![]() ![]() ![]() |
As spud said, fill new filter with diesel and no need to prime system.
Running it at a fast idle for a couple of mins also helps pull it through. Jonesie enjoying the sun before it blows a hoolie tmrw Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
