![]() | Home > Maintenance & Modifications > Removing the door cards |
Jono Member Since: 21 Aug 2015 Location: Dublin Posts: 2 ![]() ![]() ![]() |
I was wanting to remove the door card to install some sound deadening but ran into a small problem.
I can't seem to remove the lock surround. Do I need to just give it some muscle? I don't want to break it. I found this PDF which seem useful. http://www.lasalle-trim.co.uk/upload/publi...ec2013.pdf Sweeps over the lock cover though. |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Morning Jono,
Can I assume that you undid the screw holding the "door opener" (could not think of a better term) it to the door card? The door lock should just lift off with limited effort and found something like this very handy http://www.ebay.co.uk/itm/CAR-VAN-DOOR-TRI...SwstxVLmYK Let us know if this didnt help? Cheers Steve |
By lock surround, I presume you mean the escutcheon which surrounds the knob that goes up and down at the top of the door where your elbow rests ?
If so this is best removed by using the edge of a piece of 2" x 1" timber placed under the bottom edge and tapped upwards with a hammer |
As above the last sentence.
It will only come out upwards. |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
100% with Matt ![]() The edging only clips in place, and needs tapping directly upwards to remove. A small piece of wood is ideal. Guns and Landrovers .... anything else is irrelevant. |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
As above it is only the edging that comes off and not the button itself! Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
