Home > Maintenance & Modifications > Removing the door cards
Jono
Ireland 2009 Defender 90 Puma 2.4 CSW Bonatti Grey
I was wanting to remove the door card to install some sound deadening but ran into a small problem.
I can't seem to remove the lock surround. Do I need to just give it some muscle? I don't want to break it.
I found this PDF which seem useful.
http://www.lasalle-trim.co.uk/upload/publi...ec2013.pdf
Sweeps over the lock cover though.
Post #468233 1st Nov 2015 12:57am
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Morning Jono,
Can I assume that you undid the screw holding the "door opener" (could not think of a better term) it to the door card?
The door lock should just lift off with limited effort and found something like this very handy http://www.ebay.co.uk/itm/CAR-VAN-DOOR-TRI...SwstxVLmYK
Let us know if this didnt help?
Steve
Post #468242 1st Nov 2015 5:03am
By lock surround, I presume you mean the escutcheon which surrounds the knob that goes up and down at the top of the door where your elbow rests ?
If so this is best removed by using the edge of a piece of 2" x 1" timber placed under the bottom edge and tapped upwards with a hammer
Post #468249 1st Nov 2015 8:51am
As above the last sentence.
It will only come out upwards.
Post #468292 1st Nov 2015 12:19pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
100% with Matt Cool
The edging only clips in place, and needs tapping directly upwards to remove. A small piece of wood is ideal. Guns and Landrovers .... anything else is irrelevant.
Post #468310 1st Nov 2015 2:32pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
As above it is only the edging that comes off and not the button itself! Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #468368 1st Nov 2015 6:49pm
Jono
Thanks guys. Angry Puma's on Facebook helped out as well.
As you said, just got the removal tool I had and got it in from the bottom and then used a hammer to tap it off. A little too tight to do it by hand.
So i removed the two plugs at the bottom outer corner and top inner corner first.
Removed the close handle and the open handle.
Then used the Dodo Panel Popper tool to remove the card it self.
Easy when you know how. Didn't break any either.
Post #468754 2nd Nov 2015 7:59pm
