![]() | Home > Td5 > LED dome light bulb blown a fuse? |
| RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144
I was trying to replace the OE done light bulb with LED, but then all interior light and the radio stop working, I believed a fuse was blown, my question is why this could happen? No key insert , I switch the light in off position, door was open!
Is there a right way to replace LED bulb? Or the LED bulb Wattage too high? How many W should it be? Thanks Click image to enlarge |
| JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706
You may have earthed the back of the board when installing it, that will certainly do it.
How should I install it? Remove the battery egative?
Make sure the lights are off when installing
Is the LED bulb taking lots of power, so blown the fuse? Do I need to closed the door while changing the bulb?
It doesn't take much current but if you touch the circuit board to earth it will blow the fuse.
Yes, sit inside with the doors closed and interior light in the off position. |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Just put the bulb in now the fuse has blown then replace the fuse and everything should be ok. If the bulb doesn't work take the fuse back out and turn the bulb around then replace fuse. The light only uses a tiny amount of power, a lot less than a regular bulb so that shouldn't be a problem. Ray
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
When I did my first LED install, I blew the fuse as well. 1999 Defender TD5 110
| Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 |
As stated here. |
Thanks everyone!
I just put back a new fuse, lucky there are few spare fuse! but the fuse is located under the dash, not the driver seat!!!
That doesn't look like an LED bulb
I put back the OE bulb while replace the fuse...
but change to LED later this afternoon! I really the LED ambient over OE bulb! ![]() |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
Yep, Don't worry, nothing is wrong, It's VERY common, so easy to short out the contacts inside the lamp when replacing the bulbs .. Happens nearly every time if we/I forget to wait for light go off and make sure doors are all closed. I'm in the habit now of removing fuse first |
I put an extra light in my 110 and replaced all three bulbs with led and it's like daytime when I open the doors at night now
Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
