Home > Td5 > LED dome light bulb blown a fuse?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
I was trying to replace the OE done light bulb with LED, but then all interior light and the radio stop working, I believed a fuse was blown, my question is why this could happen? No key insert , I switch the light in off position, door was open!
Is there a right way to replace LED bulb? Or the LED bulb Wattage too high? How many W should it be?
Thanks Thumbs Up
Post #466704 26th Oct 2015 4:04pm
excossack
Maybe the LED is the wrong way around? Or you caught the earth and permanent live while putting the LED in ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #466766 26th Oct 2015 7:01pm
JAY BOY
Wales
You may have earthed the back of the board when installing it, that will certainly do it.
Post #466770 26th Oct 2015 7:04pm
RF3777
How should I install it? Remove the battery egative?
Post #466771 26th Oct 2015 7:09pm
JAY BOY
Wales
Make sure the lights are off when installing Thumbs Up
Post #466775 26th Oct 2015 7:13pm
RF3777
Is the LED bulb taking lots of power, so blown the fuse? Do I need to closed the door while changing the bulb? Rolling Eyes
Post #466777 26th Oct 2015 7:15pm
JAY BOY
Wales
It doesn't take much current but if you touch the circuit board to earth it will blow the fuse.
Yes, sit inside with the doors closed and interior light in the off position.
Post #466779 26th Oct 2015 7:20pm
mk1collector
Just put the bulb in now the fuse has blown then replace the fuse and everything should be ok. If the bulb doesn't work take the fuse back out and turn the bulb around then replace fuse. The light only uses a tiny amount of power, a lot less than a regular bulb so that shouldn't be a problem. Ray
My build thread
Post #466783 26th Oct 2015 7:23pm
excossack
When I did my first LED install, I blew the fuse as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #466789 26th Oct 2015 7:29pm
Martin 01
As stated here. Thumbs Up
Post #466797 26th Oct 2015 7:46pm
RF3777
Thanks everyone!
I just put back a new fuse, lucky there are few spare fuse!
but the fuse is located under the dash, not the driver seat!!! Idea
Post #466886 27th Oct 2015 3:33am
mk1collector
That doesn't look like an LED bulb Question Ray
My build thread
Post #466934 27th Oct 2015 10:52am
RF3777
I put back the OE bulb while replace the fuse...
but change to LED later this afternoon! Mr. Green
I really the LED ambient over OE bulb! Thumbs Up
Post #466946 27th Oct 2015 11:27am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Yep, Don't worry, nothing is wrong, It's VERY common, so easy to short out the contacts inside the lamp when replacing the bulbs .. Happens nearly every time if we/I forget to wait for light go off and make sure doors are all closed.
I'm in the habit now of removing fuse first Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #466961 27th Oct 2015 12:19pm
mk1collector
I put an extra light in my 110 and replaced all three bulbs with led and it's like daytime when I open the doors at night now Mr. Green
 Ray
My build thread
Post #466964 27th Oct 2015 12:26pm
